BK7258 RGB PCB is back
A project log for Triple M33 low-power portable display
BK7258 is connected to 2x2.16" 480x480 AMOLED, one L1+L5 frequency band GPS module, and one SIM7670G 4G module. And 4 sensors.
eleclabElecLab 04/12/2026 at 03:460 Comments
PCB uses 4 layers of 1mm thickness and 0.3/0.45mm drilling.
 There are two LCD sockets on the PCB, one is 40P SPI+RGB666+TP. There are many types of this small screen with capacitance touch. Generally, the SPI port needs to be used to initialize the LCD screen chip.
 The other is an ordinary 40P 4.3" 5" 7" regular TFT screen, which uses a separate 6P TP FPC to connect a capacitive touch screen.
 Typical screen sizes and resolutions are listed behind the PCB.
