Saturday
A project log for Pixhawk 6C UAV Data Collection Platform
A modular 4S quadcopter test platform built around Pixhawk 6C for manual flight, autonomous control, telemetry, and airborne data collection
rhea-raeRhea Rae 04/11/2026 at 16:430 Comments
I finally decided to put the quad back together today. The first test flight on this build went well and that was completely manual. After that I started using the programmed flight learning on the PC, and that is where things went sideways. I accidentally programmed it right into a tree and the whole thing became a nightmare, so it ended up sitting for a while.
Today I took a few hours and started bringing it back. I installed the motors onto new arms and reconnected part of the system. At this point I still need to pull the FlySky controller from the water drone, connect the battery, and run tests. I will probably do that tomorrow.
What I like about this build is that it does both. It can be flown manually, but it also has the hardware for autonomous flight through the Pixhawk 6C, M10 GPS, and 915 MHz telemetry. So it is not just a quad, it is a platform for both direct control and programmed behavior.
-RR
