⚙️ Implementation Notes (NKTg Law)
Runtime Model
The system operates as a discrete-time loop rather than a continuous equation solver.
At each iteration:
- Input state is sampled (x, v, m)
- Mass variation (dm/dt) is either measured or estimated
- Motion tendency is computed directly
This avoids solving differential equations and allows integration into real-time systems.
Data Flow
Input → Compute → Evaluate → React
- Read current state
- Compute momentum (p = m × v)
- Compute NKTg components
- Compare directional influence
- Output system response
This structure is intentionally simple to support embedded environments.
Why Not Differential Equations?
Traditional models rely on:
- Continuous integration
- Numerical solvers (RK4, Euler, etc.)
- High computational cost
In contrast, NKTg uses:
- Direct computation
- Discrete updates
- Low overhead
This makes it suitable for:
- Microcontrollers
- Real-time AI loops
- Edge devices
Behavior Interpretation Layer
Instead of solving trajectories explicitly, the system evaluates tendencies:
- Directional reinforcement
- Resistance effects
- Stability convergence
This allows decision systems (AI, controllers) to act immediately.
Integration Strategy
The model is designed to plug into existing systems:
- Robotics → control loop replacement
- AI → feedback signal generator
- Simulation → lightweight physics core
- Embedded → real-time motion estimation
No full physics engine is required.
Performance Considerations
- O(1) per step computation
- No iterative solver required
- Minimal memory footprint
- Suitable for Assembly-level optimization
System Philosophy
The goal is not to replace classical physics.
The goal is to make motion:
- Computable
- Executable
- Integratable into software systems
Reference (Full System + Multi-language Code)
🔹 Leanpub
https://leanpub.com/NKTgLaw https://leanpub.com/NKTgLaw-vi https://leanpub.com/b/NKTgLaw-global
🔹 Google Play Books
https://play.google.com/store/books/details?id=CNLKEQAAQBAJ&pli https://play.google.com/store/books/details?id=buDMEQAAQBAJ https://play.google.com/store/books/series?id=Fa6gHAAAABC0sM
🔹 Amazon
https://www.amazon.com/dp/B0GTSBBRYR https://www.amazon.com/dp/B0GHZMSKYB https://www.amazon.com/dp/B0D6579Q3G
Keywords
NKTg Law • Varying Inertia • Variable Inertia AI that reacts like physical systems Autonomous vehicles with real-time physics engines Simulation that doesn’t approximate — it executes Space navigation beyond classical models
Nguyen Khanh Tung
Jovan
little french kev
Andrew
Is constant inertia an oversimplification in modern engineering systems?
