Specs:
| Processor | Raspberry Pi CM5 (CM4 compatible*) |
| Cooling | Aluminum rear housing + integrated fan |
| Storage | NVMe M-key slot for 2230 SSD |
| MicroSD | TF / MicroSD card slot (CM5 without MMC) |
| MCU | RP2040 MCU |
| Display Output | Mini-HDMI 2.0 |
| USB 3.0 | 1x USB-C port 5Gbps (CM5 only*) |
| USB 2.0 | 3x ports (1x USB-C, 1x USB-A external, 1x USB-A internal) |
| Ethernet | 10/100/1000 Mbps RJ45 |
| Audio | 3.5mm headphone jack, S/PDIF out |
| Wireless | WiFi 6 / BT 5 (with wireless CM variant) |
| NFC | NFC reader / writer |
| GPIO | 40-pin Raspberry Pi header (top edge) |
| Infrared | 940nm TX/RX |
| MIPI | 2x 4-lane (camera and display) |
| Optional 4G/LTE | WWAN module + micro SIM slot |
| Battery | 8000mAh Li-ion (2S configuration) |
| Charging | Bi-directional up to PD 27W |
| Output (future) | 100W supported by hardware* |
| Accessory Power | 6 amp 5V and 3.3V rails |
| Included Cable | USB-C with voltage/amps/watts display |
| Display | 4.3" 800x480 IPS |
| Camera | 5MP 72-degree with autofocus |
| Keyboard | Backlit full QWERTY (QMK firmware) |
| Gamepad | Nintendo Switch-style joystick (mouse control) |
| Audio | High-quality DAC, Class-D 5W amplifier |
| Speakers | High-quality stereo speakers |
| Volume Control | Tactile analog wheel |
| Torch | High brightness LED |
| Dimensions | 110W x 160H x 18D mm |
| Weight | 260g |
tangles
ACROBOTIC Industries
Billy RB Wang
helge
Yes, I’d like to see this in operation and as an assembled or kit project.
