https://3dj77.github.io/Springhouse-Projects/
April 23, 2026 -
We are now up to 500 watts of solar panels (on the 24v system) and 200 watts of solar panels on the primary 12v system, as well as having the temporary ground mount for the first string of 5 solar panels built and installed. Now we need to keep testing locations to find the best placement for the permanent ground mount to be installed. Small form factor pc load draw doesn't even make a dent now. I am testing to see if how long it will run (powered it on at 11:30 AM and is still up at 4:15pm. Will begin solar dashboard configuration next.
Jeremiah
