The Propulsion Concept
As shown in Image 2, the system acts as a concentrated solar power (CSP) plant inside a balloon. The transparent polymer allows light to enter with minimal refraction, while the internal reflective surface (Image 1) focuses solar radiation onto a Silicon Carbide honeycomb receiver. This creates a high-density thermal exchange, heating the internal air (T_int > T_ext) to generate Archimedean buoyancy.
Mechanical Innovation: The Exoskeleton
To maintain optical alignment during flight, NIMBUS uses a rigid exoskeleton (Image 3). This framework features C-shaped tracks (Image 3 & 4) that house a tension-cable system. This allows the internal concentrator to rotate on two axes, tracking the sun regardless of the balloon’s orientation. This kinematics system was successfully validated using a 16cm physical scale model (Image 5).
Empirical Validation
The core thermodynamic principle was tested using a simplified parabolic section (Image 6). Using only a foil-lined shell and a standard thermometer, focal point temperatures reached 41°C within seconds from an ambient of 22.5°C, demonstrating the rapid energy transfer potential of the design.
The "Solar Theater" Infrastructure
To assist with the initial lift-off—the most energy-intensive phase—NIMBUS utilizes a ground-based "Solar Theater." This is a semi-circular array of heliostats located on a south-facing slope that beams additional energy into the sphere, acting as a thermal catapult for takeoff.
Michele Lorenzi
Dennis
Koichi Kato
Anteneh Gashaw
The way this project looks like some LLM spat it out is almost as bad as the fundamentally flawed appraoch at its core.
There's only natural convection inside. Light a candle indoors with no draft and hold your hand directly above it at a distance of 20-30 cm. I'm sure it'll only take you seconds to understand what the problem is.
