Phase 2: NIMBUS-E — The Hybrid Thermal-Electric System
A project log for NIMBUS - Solar Balloon for Human Flight
Nimbus: An Open-Source aerostat using an internal solar concentrator and ceramic receiver to generate thermal lift. Clean flight, no fuel.
michele-lorenziMichele Lorenzi 05/05/2026 at 09:500 Comments
Note: images referenced below are planned. Prompts for generating them with AI image tools are included at the end of each section. Contributions are welcome.
Concept
Once the core thermal lift system of Phase 1 is validated, the natural next step is to add onboard electrical generation. This transforms NIMBUS from a passive solar aerostat into a partially steerable hybrid airship: NIMBUS-E.
1. Spectrum Splitting at the Receiver
Sunlight concentrated onto the ceramic receiver contains three components:
ComponentShareRole
Near-infrared~50%Heats internal air → lift
Visible light~45%Intercepted by PV layer → electricity
Ultraviolet~5%Absorbed as additional heat
A thin photovoltaic layer is added to the front face of the ceramic receiver. Visible light is converted to electricity before the remaining radiation heats the SiC honeycomb behind it. This is called spectrum splitting and is an active area of research in concentrated solar power (CSP) systems.
Important design note: Standard silicon PV cells fail above ~80°C and cannot survive near the ceramic receiver. NIMBUS-E will use either GaAs (Gallium Arsenide) cells — which tolerate high irradiance and elevated temperatures — or position the PV layer slightly offset from the ceramic core, in the cooler airstream, so that infrared passes through to the honeycomb while visible light is captured. Both approaches are being evaluated, as well as the possibility to use a Dichroic Mirror or a Beam Splitter.
Estimated electrical output: modest but sufficient for tracking motors, sensors, communications, and partial propulsion.
Image 7 — Receiver cross-section diagram AI image prompt: "Technical cross-section diagram of a solar receiver: a Silicon Carbide honeycomb block behind a thin photovoltaic layer, labelled arrows showing near-infrared passing through to the ceramic, visible light absorbed by the PV layer, white background, clean engineering style."
2. Thermal Battery — Flying After Sunset
Because the receiver operates at high temperature, it naturally acts as a thermal mass. Phase 2 will explore integrating Phase Change Materials (PCM) — substances that store and release large amounts of heat during melting and solidification — inside or around the ceramic receiver.
This would allow NIMBUS-E to remain buoyant for 1–2 hours after the sun goes down, using stored heat rather than active solar input. This is a significant safety and operational advantage over conventional aerostats, which lose lift immediately when solar input drops.
Image 8 — PCM thermal storage diagram AI image prompt: "Schematic diagram of a thermal battery integrated into a ceramic receiver block, showing Phase Change Material layer surrounding a SiC honeycomb, arrows indicating heat storage and release cycle, clean technical illustration, white background."
3. Onboard Electrical Systems Enabled
The electricity generated opens four new capabilities:
Autonomous Sun Tracking The two-axis cable mechanism of Phase 1 is motorised, replacing manual control with a sensor-driven automatic tracking system. This improves optical precision and reduces pilot workload.
Image 9 — Tracking motor integration diagram AI image prompt: "Diagram of a two-axis cable-driven solar tracking mechanism inside a transparent sphere, with small electric motors at the cable anchor points, labelled, clean engineering drawing style, white background."
Altitude Control The electricity produced can be used for a Ballonet: it's an internal bag you inflate with outside air to make the balloon heavier and descend.
Steering and Station-Keeping Small electric thrusters or vectored fans on the gondola provide limited directional control — enough to compensate for wind drift and hold a position. Full horizontal flight is beyond the scope of this system, but meaningful station-keeping transforms NIMBUS-E from a balloon at the mercy of the wind into a genuinely steerable platform.
Image 10 — Propulsion pod concept AI image prompt: "Concept illustration of a small gondola beneath a large transparent spherical balloon, with two small vectored electric thrusters mounted on the sides, clean technical concept art style, blue sky background."
Onboard Instrumentation Sensors, cameras, communication systems and data loggers powered indefinitely during daylight hours, making NIMBUS-E a capable aerial observation and research platform.
4. Impact on Envelope Size
Recovering an estimated 8–10% of total solar input as electricity reduces the thermal load required for lift. This allows a modest reduction in envelope diameter — approximately 5–10% compared to Phase 1 — while maintaining the same payload capacity. Supporting calculations will be published in the /calculations folder.
5. Commercial Applications
Station-keeping capability fundamentally changes the commercial proposition of NIMBUS. A steerable, fuel-free solar airship opens applications in:
These are markets with established demand — making NIMBUS-E a significantly more attractive proposition for the crowdfunding campaign planned for Phase 3.
Status
Planned — pending successful validation of Phase 1 thermal lift system.
Contributions and simulations related to spectrum splitting, high-temperature PV cells, PV-thermal hybrid receivers, Phase Change Materials, and electric propulsion at aerostat scale are welcome. Open an Issue or contact the author directly.
"The crisis requires sharing, not secrecy."
