The unit was opened and the battery identified as a Seiko MS621FE. The battery's voltage was measured at 2.55V and the size measured at 6.70mm. Note the configuration of the battery tabs, which must be installed carefully to avoid a short circuit. A new battery was installed.
Silícios Lab
PlastiBots.com
David Hopkins
