Editor is on its way
A project log for MCU pin setup
Visual pin layout setup tool for development boards with an editor mode for community involvement
norbert-feketeNorbert Fekete 05/31/2017 at 10:580 Comments
It may look like I've been doing nothing with the MCU pin setup webpage in the last few weeks:
https://hubberthus.github.io/
Well, it's because I haven't. :)
What I've actually been doing is on the "editor" branch, which can be found here:
https://github.com/Hubberthus/hubberthus.github.io/tree/editor
With the editor anyone will be able to easily modify and/or add cores/modules to the MCU pin setup tool.
It can be tested out by getting the source and double-clicking on the "index.html", no webserver is needed actually for the page to run, just a good browser.
Anyway, the "editor" branch is unstable and for now is nearly completely useless. But I'm working on it, and when it becomes usable, I'll merge it into the so-to-say release branch.
Features expected to be done:
