M3-CRETE
Open-source meter-scale concrete 3D printer. CadQuery with self-verifying assembly harness.
0 followers
The M3-CRETE Open-source 3D Concrete Printer - Meter Scale, Mobile and Modular for 1-4 M^3 build volumes. Assembled using CADCLAW - AI-enabled CAD assistant for interference and assembly.
A meter-scale cartesian gantry purpose-built for extruding cementitious materials, fully defined in Python, released under CERN-OHL-W-2.0. Every dimension is a variable. Every part is off-the-shelf. The full assembly STEP file is attached to this project.
## Why this exists
Most additive-construction hardware is sized for, and priced for, large general contractors and capital-rich early adopters. The end of the market that 3DCP serves least well is the operator we built for: a small concrete printer, a regional contractor, a university lab, a cement-plant new-product group, a maker space, an independent researcher. M3-CRETE is a reference design for that audience. The CAD, the BOM, the assembly conventions, and the verification harness are all open and reproducible. If the design helps you ship something proprietary on top, the license allows that. If you modify the printer hardware itself and redistribute it, your modifications stay open.
## What the M3-2 is
The M3-2 is the default variant of M3-CRETE, a cartesian gantry purpose-built for extruding cementitious materials. Build envelope 2000 x 1000 x 1000 mm inside a frame roughly 2080 x 1080 x 1080 mm. The full meter of Z travel is recovered from 1000 mm Z-posts by using the bottom Y-skid as structural floor (the build surface sits above it, not below), mounting the Z motors high on the posts, and offsetting the printhead. Big enough to print a standard CMU, a landscape retaining-wall section, or a structural column form in a single run.
Seven NEMA23 steppers drive the machine: one X, two Y (anti-racking), four Z (independent belt-driven posts for Klipper Z_TILT_ADJUST self-tramming). A BigTreeTech Kraken with eight onboard TMC5160 drivers runs the movement, leaving the final motor slot for a printhead. The printhead mounts via 1-inch NPT and targets a featherweight 1.5 kg, deliberately light so the frame elements and motors stay small enough to be safe for use in training as well as production.
## One extrusion. One length. One bolt kit.
Every structural member is a 40 x 80 C-beam. Not a mix of 2040 and 2080 V-slot. Not custom cuts. One SKU, one bolt kit, one assembly convention. If you want to order the frame, you order this part and nothing else.
Length is a shipping decision, not a structural one. The C-beam's stiffness means the frame works at 1000, 1200, or 1500 mm stock with the same bolt patterns and the same assembly. Pick 1000 mm if you want the kit to fit in standard ground-parcel boxes. Pick 1200 or 1500 mm if you want a larger printer. The parametric CAD auto-adjusts the splice count when the stock length changes.
Earlier revisions of the M3-2 used mixed 2040 and 2080 V-slot with spliced X-rails. It worked, but it fragmented procurement into four SKUs, three lengths, and two splice methods. C-beam solves all of that at once:
- **Procurement simplified.** The reference build calls for 18 pieces of 40 x 80 C-beam, which ships in two standard ground-parcel boxes at 1000 mm stock or one pallet at longer lengths.  17 pieces are required for the M3-2 version leaving an extra piece in case of damage (these are only shipped in pairs from some suppliers).
- **Bending stiffness is better.** A 40 x 80 C-beam is stiffer than either 2040 or 2080 in the critical axes, and the channel itself acts as a stress-relief rib.
- ******* Safety & security  ***** Belts run inside channels instead of exposed - reducing pinch points and protecting those belts and pullies from damage, dirt and debris.
- **more rugged - more options ** Four V-groove faces plus a channel mean you can mount additional wheels for heavier equipment.
- **Honest cost and weight penalty.** A C-beam is heavier and slightly more expensive than a 2080. For a frame in a worksite environment we accepted the extra weight and cost for strength, stuffness and safety.
One caveat up front: the 2000 mm spans require splicing at center, regardless of stock length, two equal-length...
M3-2_V1.0.step
Latest assembly with all components shown. small hardware (screws/washers/spacers) not included to keep size manageable.
step - 8.50 MB - 04/30/2026 at 09:36
Download
  • Bringing the brains online: Klipper, quad-Z, and sensorless endstop tuning.
    Nick06/14/2026 at 13:40 1 comment
    The frame and wiring are done, so this milestone is about the part that turns a
    pile of aluminum and steppers into something that actually moves: the software.
    M3-CRETE runs Klipper on a Raspberry Pi 5, driving a BigTreeTech
    Kraken — the 8-driver board with onboard TMC5160s. That driver count is exactly
    why we picked it: the full machine is 4× Z + 1× X + 2× Y + 1× extruder = 8 motors,
    all on integrated high-current drivers, with the concrete pump handled separately
    (more on that below).
    We're bringing it up in stages instead of flashing one giant config and
    hoping. Stage 1 is just the four Z motors on the first four driver slots, with
    sensorless homing — no limit switches anywhere on the machine. Each Z corner
    drives up into the top brace until its TMC5160's StallGuard fires, and that stall
    point becomes the corner's zero. Four corners, four independent stalls, coplanar
    without a probe (ever gotten wet concrete on an endstop? sensorless isn't
    a flex here — it's the only option that survives the environment.)
    Two things that will bite you on a Kraken
    While verifying pins against BTT's official config, two details jumped out that
    silently wreck a lot of copy-pasted setups:
    The Kraken's onboard drivers use software SPI (PC6/PC8/PC7), not a hardware
    SPI bus.
    Its sense_resistor is 0.022 Ω, not the 0.075 that generic TMC5160 module
    guides use. Get that wrong and every run_current you set is off by ~3.4×.
    The pump is not a stepper
    The concrete pump is a MAI 2PUMP Pictor, which takes a 0–10 V analog speed
    command — and neither Klipper nor the Kraken has a DAC. The trick: define the
    pump as a Klipper [extruder_stepper] synced to the extruder, route its STEP
    pulse train into a frequency-to-voltage converter, and you get a 0–10 V command
    that tracks extrusion in real time, with pressure-advance to pre-pressurize the
    hose. Start/stop is a separate 24 V line through an opto/relay (0 V doesn't stop
    the pump — it has a minimum-flow deadband). That's a later stage implementation (we demonstatred ove a year ago) , but it's the neat bit, so it gets a mention.
    Open-sourced this round
    Full Klipper config + a one-line installer (install.sh) that drops the
    config in, registers it with Moonraker's update manager (so it's click-to-update,
    same as Klipper itself ), installs KlipperScreen, and
    auto-detects the board's serial:
    github.com/sunnyday-technologies/M3-CRETE-FIRMWARE
    A plain-language software build guide, written so a complete beginner can
    follow it and so it translates cleanly:
    m3-crete.com/build-guide/software/
    Where it stands:
    This milestone ends at first motor movement — energize, jog each Z motor, verify
    direction. Setting working current, tuning StallGuard, homing all four corners, and
    the full pre-print qualification are the next guide (validation). It is a
    development platform, not a certified appliance, and it is not printing concrete yet.
    Build along, or tell us what we got wrong — the whole point of doing this in the
    open is that the next builder hits fewer walls than we did.
  • # Building a Meter-Scale Parametric CAD Assembly with an AI Coding Agent (and What Actually Worked)
    Nick04/30/2026 at 10:40 0 comments
    M3-CRETE is an open-source concrete 3D printer. The motion system, the frame, gantry, motors, belts, wheels, every part that moves, was designed in Python using CadQuery, a code-based CAD library. No Fusion 360 was used to *author* the geometry, though Fusion was used extensively to *verify* and refine it.
    The unusual part: an AI coding agent was the primary tool for writing the CadQuery assembly script. Here is what that looked like in practice.
    ## The Setup
    The M3-2 variant of M3-CRETE has a meter-scale build volume on a frame roughly two meters across. Eight plates, dozens of V-wheels, motors, pulleys, idler bearings, belts, and 3D-printed motor brackets. Every part position depends on the frame dimensions, so changing the width means dozens of parts need to move.
    In GUI CAD, that means dozens of manual edits or an elaborate constraint system. In code-CAD, it means changing one number and re-running a script.
    The agent's job: write and maintain that script.
    ## What the Agent Does Well
    **Coordinate math.** The M3-2 frame has four corner posts. Every plate, wheel, motor, and pulley position derives from those four post positions plus offsets. The agent handles this reliably once the conventions are established.
    **Repetitive placement.** Four Z-carriages, each with plates, wheels, a motor, a pulley, an idler, and belt strands. Define the pattern once, the agent replicates it to all four corners with correct mirroring.
    **Refactoring.** When the frame switched from mixed extrusion lengths to a single SKU, the agent rewrote every placement coordinate in a single pass.
    ## The Real Contribution: Self-Verification
    Here is the thing nobody talks about in the AI-does-CAD conversation: how do you know the output is correct?
    We built a verification harness, a second Python script that loads the assembly, extracts every part's bounding box, and runs hundreds of engineering checks against it. Does this plate measure 3 mm thick? Is this wheel engaging the V-groove at the correct depth? Does this belt span from the idler to the motor pulley?
    If any check fails, the harness tells the agent exactly what is wrong. The agent fixes the assembly script and re-runs. No human needs to open Fusion 360 to catch dimensional errors.
    The harness also renders three orthographic views (top, front, side) using matplotlib, no 3D rendering engine required. The agent reads those images and compares them against reference renders. That closes the loop. The agent can see its own mistakes without human intervention.
    The verification approach we built for M3-CRETE was eventually packaged as a standalone open-source tool, [CADCLAW](https://cadclaw.io), so other projects can apply the pattern to their own assemblies.
    ## What the Agent Gets Wrong
    **Mechanical intent.** The agent can place a plate at a coordinate. It does not understand *why* a sandwich joint differs from a butt joint. That understanding comes from the engineer. Every time.
    **Part orientation.** STEP files from component libraries have arbitrary orientations. A motor might be lying on its side. We wrote a probe script to measure bounding boxes before placement, which helps, but orientation errors remain the most common bug class.
    **Session memory.** The agent forgets prior decisions between sessions. We maintain explicit notes and transfer summaries to bridge sessions. It is manual and imperfect.
    ## The Hybrid Approach
    The assembly script evolved from pure parametric generation to a hybrid. It loads the engineer's Fusion 360 export and surgically replaces specific components with parametric versions. That preserves the human's mechanical refinements while keeping the ability to regenerate components from code.
    This is pragmatic engineering, not a purity contest. The human's GUI model is usually better than the agent's parametric recreation. The agent's value is in the verification infrastructure, not in replacing the human's judgment.
    ## What This Buys
    - Assembly geometry that...
  • Assembly begins
    Nick04/30/2026 at 09:42 0 comments
    Starting Assembly - we have printed the motor-mount + spacer pieces so we will begin assembly.  still working on the  small  3d printed retainers to hold the 2040 reinforcement inside the 2-meter 4080 c-beam sections.
View all 3 project logs
