TRIPLE-DRIVE PMM/PMG COMBO
Grid-Tie & Backup Storage System
Hackaday Green Powered Challenge — 2026
CYR Technologies · Chicago, IL · Wolf13
Public Domain Prior Art Declaration · April 2026
WHAT THIS IS
A home power generation, storage, and community grid-feed system
built around a triple-motor permanent magnet outrunner and a
cog-relief permanent magnet generator. No combustion. No fuel.
No external excitation required. All mechanical details declared
public domain.
THE DRIVE STAGE — TRIPLE-MOTOR OUTRUNNER
One outrunner shell. Three motors inside it — M1, M2, M3 —
separated by 120 degrees each. The axle runs all the way through
the assembly, anchored at both ends to fixed frame posts.
Three motors at 3 cog positions each = 9-position total cog cycle.
At no point in the rotation are all three motors at dead center
simultaneously. The shell always has at least one motor in push
or pull drive. Dead center is never shared.
The three staggered drive pulses per cog cycle deliver a far
smoother torque stream to the flywheel than any single-motor
design. The flywheel integrates what remains and delivers clean
continuous rotation to the PMG output stage.
THE 4-POST ASSEMBLY
Left to right:
  POST 1 ── Fixed to frame. Axle anchored here. Does not rotate.
  OUTRUNNER ── Single shell, three internal motors, 120° offset.
  POST 2 ── Bearing support. Axle supported after outrunner.
  FLYWHEEL ── On spinning axle. Bearing-supported both sides.
  POST 3 ── Bearing support. Flywheel supported far side.
  PMG ── Cog-relief permanent magnet generator. DC output.
  POST 4 ── Fixed to frame. Far end anchor.
Two fixed posts (1 and 4). Two bearing posts (2 and 3) flanking
the flywheel. Axle spins continuously through all stages.
THE OUTPUT STAGE — COG-RELIEF PMG
AC induction generators are the wrong tool for battery charging.
They require external magnetization, suffer high rotor losses
from copper windings, and drop efficiency sharply at partial load
— exactly when a battery bank charges most of the time.
Peak efficiency of AC induction: 80–93%.
The cog-relief PMG is self-excited, near-zero rotor losses, and
holds 90–97.5% efficiency across the entire load curve including
partial load. For a battery charging application it is the only
correct choice.
THE STORAGE STAGE
PMG output → MPPT charge controller → 48V battery bank →
inverter → home.
MPPT (Maximum Power Point Tracking) is the proven standard from
solar installations. It continuously optimizes charge rate
regardless of PMG output variation.
48V is the established residential storage standard — widest
compatibility with off-the-shelf BMS units, inverters, and
monitoring equipment. Lower current than 12/24V systems means
less heat, thinner wire, better overall efficiency.
THREE FUNCTIONS OF THE BATTERY BANK
PRIORITY 1 — HOME FIRST
  Refrigerator, lights, tools, essential appliances.
  The home is always covered first. No grid dependency
  for daily needs.
PRIORITY 2 — GRID OVERFLOW
  Genuine surplus feeds into neighborhood grid at night —
  when solar produces nothing and conventional generation
  carries all load. Fills the temporal blind spot solar
  leaves behind. No cost to the homeowner.
PRIORITY 3 — MECHANICAL BACKUP
  If the outrunner assembly requires maintenance or repair,
  stored energy bridges the gap. Any service window becomes
  a planned event, not an emergency. The home never loses
  power during repair.
THE NIGHT GAP — COMMUNITY...
