TRIPLE-DRIVE PMM/PMG COMBO
Grid-Tie & Backup Storage System
Hackaday Green Powered Challenge — 2026
CYR Technologies · Chicago, IL · Wolf13
Public Domain Prior Art Declaration · April 2026
WHAT THIS IS
A home power generation, storage, and community grid-feed system
built around a triple-motor permanent magnet outrunner and a
cog-relief permanent magnet generator. No combustion. No fuel.
No external excitation required. All mechanical details declared
public domain.
THE DRIVE STAGE — TRIPLE-MOTOR OUTRUNNER
One outrunner shell. Three motors inside it — M1, M2, M3 —
separated by 120 degrees each. The axle runs all the way through
the assembly, anchored at both ends to fixed frame posts.
Three motors at 3 cog positions each = 9-position total cog cycle.
At no point in the rotation are all three motors at dead center
simultaneously. The shell always has at least one motor in push
or pull drive. Dead center is never shared.
The three staggered drive pulses per cog cycle deliver a far
smoother torque stream to the flywheel than any single-motor
design. The flywheel integrates what remains and delivers clean
continuous rotation to the PMG output stage.
THE 4-POST ASSEMBLY
Left to right:
  POST 1 ── Fixed to frame. Axle anchored here. Does not rotate.
  OUTRUNNER ── Single shell, three internal motors, 120° offset.
  POST 2 ── Bearing support. Axle supported after outrunner.
  FLYWHEEL ── On spinning axle. Bearing-supported both sides.
  POST 3 ── Bearing support. Flywheel supported far side.
  PMG ── Cog-relief permanent magnet generator. DC output.
  POST 4 ── Fixed to frame. Far end anchor.
Two fixed posts (1 and 4). Two bearing posts (2 and 3) flanking
the flywheel. Axle spins continuously through all stages.
THE OUTPUT STAGE — COG-RELIEF PMG
AC induction generators are the wrong tool for battery charging.
They require external magnetization, suffer high rotor losses
from copper windings, and drop efficiency sharply at partial load
— exactly when a battery bank charges most of the time.
Peak efficiency of AC induction: 80–93%.
The cog-relief PMG is self-excited, near-zero rotor losses, and
holds 90–97.5% efficiency across the entire load curve including
partial load. For a battery charging application it is the only
correct choice.
THE STORAGE STAGE
PMG output → MPPT charge controller → 48V battery bank →
inverter → home.
MPPT (Maximum Power Point Tracking) is the proven standard from
solar installations. It continuously optimizes charge rate
regardless of PMG output variation.
48V is the established residential storage standard — widest
compatibility with off-the-shelf BMS units, inverters, and
monitoring equipment. Lower current than 12/24V systems means
less heat, thinner wire, better overall efficiency.
THREE FUNCTIONS OF THE BATTERY BANK
PRIORITY 1 — HOME FIRST
  Refrigerator, lights, tools, essential appliances.
  The home is always covered first. No grid dependency
  for daily needs.
PRIORITY 2 — GRID OVERFLOW
  Genuine surplus feeds into neighborhood grid at night —
  when solar produces nothing and conventional generation
  carries all load. Fills the temporal blind spot solar
  leaves behind. No cost to the homeowner.
PRIORITY 3 — MECHANICAL BACKUP
  If the outrunner assembly requires maintenance or repair,
  stored energy bridges the gap. Any service window becomes
  a planned event, not an emergency. The home never loses
  power during repair.
THE NIGHT GAP — COMMUNITY RESILIENCE
Solar net metering has proven that distributed generation can
feed back into neighborhood grids. This system applies the same
principle to the temporal blind spot: the hours after sunset
when solar is zero and neighbors without any renewable setup
receive no benefit.
The flywheel-smoothed, battery-buffered output is well-conditioned
for grid-tie inverter use. Home is protected first. Only genuine
overflow feeds the grid. The community benefit is real and costs
the homeowner nothing.
Where solar is already installed, this system fills the night gap
rather than duplicating daytime generation. The two technologies
are complementary — solar owns the day, this system owns the
night. Together they approach continuous renewable coverage.
WHY IT WORKS
1. Three motors at 120° separation inside one shell.
   9-count cog cycle. Dead center never shared across all three.
   Continuous drive output.
2. Cog-relief PMG: self-excited, 90–97.5% efficiency,
   exceptional at partial load. Right tool for battery charging.
3. Flywheel: bearing-supported both sides, no cantilevered load.
   Receives smooth three-pulse torque stream, delivers clean
   rotation to PMG.
4. 48V storage: maximum component compatibility, lower losses
   than 12/24V, proven residential standard.
5. Battery as resilience, not just capacity. Mechanical backup
   built in. Service windows become planned events.
6. Night grid overflow complements existing solar infrastructure.
   No duplication — fills the temporal gap.
7. No combustion. No fuel. No emissions. No noise.
   Runs on established, available, off-the-shelf components.
PUBLIC DOMAIN DECLARATION
All mechanical details in this submission are declared public
domain prior art. No patents filed. No patents intended for
the mechanical architecture described here.
This record is established April 2026.
Alan Cyr · Founder & CTO
Wolf13 · 🐺⚡
Hackaday Green Powered Challenge · 2026
Public domain submission — mechanics only
═══════════════════════════════════════════════════════════════════// CYR Technologies — Hackaday Green Powered Challenge
Triple-Motor PMM Outrunner
Three motors inside one outrunner shell — 9-position cog cycle, continuous drive, flywheel-integrated, battery-buffered, home-first with community grid overflow at night.
Green Powered
Grid-Tie
48V Storage
Community Resilience
No Combustion
01
The Problem This Solves
Solar is transforming home energy — but it has a hard edge: it stops at sunset. The hours when neighbors without solar need power most — evenings, night — are exactly when solar produces nothing. Single-generator setups have a second problem: mechanical failure means a dark house. This system addresses both.
The Night Gap
Solar feeds the grid all day. At night the grid reverts to conventional generation. Neighbors without storage get no renewable benefit after dark.
Single Point Failure
One generator — one failure point. Any mechanical issue cuts power immediately with no bridge to keep critical loads running during repair.
No Output Buffer
A PMM without flywheel integration passes torque variation directly to the generator. A flywheel on the same axle smooths rotation and protects downstream electronics.
02
The Mechanical Stage — Triple-Motor Outrunner Assembly
One outrunner shell. Three motors inside it, separated by 120° each. The axle runs all the way through the assembly — anchored at both ends to fixed frame posts, spinning through all stages. The three motors share the single rotating outer shell and are angularly positioned so their cog cycles are offset by one third of a full rotation. With three motors at 3 positions each, the total cog count is 9. At no point in the rotation are all three motors at dead center simultaneously — the shell always has at least one motor in push or pull drive.
After the outrunner, the spinning axle passes through two bearing-supported posts flanking the flywheel, drives the generator, then terminates at a fixed frame post. The flywheel receives an already much smoother torque input than a single-motor design — three staggered drive pulses per cog cycle instead of one.
POST 1
Fixed/Frame
Axle anchor
M1
M2
M3
120° · 120° · 120°
Triple-Motor Shell
9-count · outer shell rotates
POST 2
Bearing
FLY
WHEEL
Inertia
smooth output
POST 3
Bearing
AC
GEN
Generator
AC output
POST 4
Fixed/Frame
Far anchor
━━━━━━━━━━ AXLE RUNS FULL LENGTH — SPINS THROUGH ALL STAGES ━━━━━━━━━━
Posts 1 & 4: Fixed to frame. Anchor the axle at both ends. Do not rotate.
Posts 2 & 3: Bearing-supported. Flywheel held between them — supported both sides, no cantilevered load.
Three motors · one shell: M1, M2, M3 separated by 120° inside the single rotating outer shell. 3 motors × 3 positions = 9-count cog cycle. Dead center is never shared across all three.
Flywheel: Receives three staggered drive pulses per cog cycle. Delivers smooth continuous rotation to the generator.
03
System Block Diagram — Energy Path
M1 · M2 · M3
3 motors · 1 shell · 9-count
Flywheel
Ripple integrator
Generator
AC output
MPPT
Charge control
48V Bank
Battery storage
Inverter
DC → AC
OUTPUT PRIORITY:
① Home First
Appliances · Refrigerator · Lights · Tools
② Grid Overflow
Night gap fill · Community feed
③ Backup Reserve
PMM maintenance · Mechanical failure bridge
04
The Storage Stage
Generator output feeds an MPPT charge controller — the same technology proven in solar installations — which maximizes charge efficiency into a 48V battery bank. The 48V standard gives the widest compatibility with off-the-shelf inverters, BMS units, and monitoring equipment. The inverter converts stored DC to AC for the home. The battery serves three distinct functions simultaneously.
PRIORITY 1
Home Power
Refrigerator, lights, tools, and essential appliances. The home is always covered first from stored energy — no grid dependency for daily needs.
PRIORITY 2
Grid Overflow
Genuine surplus feeds into neighborhood distribution at night — when solar produces nothing and demand peaks. Fills the temporal gap solar leaves behind.
PRIORITY 3
Mechanical Backup
If the outrunner assembly requires maintenance or repair, stored energy bridges the gap. No outage during service. The system is self-protecting.
05
The Night Gap — Community Grid Reinforcement
Solar net metering has proven that distributed generation can feed back into neighborhood grids. This system applies the same principle to the temporal blind spot: night hours when solar is zero and conventional generation carries all load. Neighbors without any renewable setup receive a real benefit — not just during daylight hours when solar already overproduces, but during the hours it matters most.
The flywheel-smoothed, battery-buffered output is well-conditioned for grid-tie inverter use. No raw generator ripple reaching the grid. Home is protected first. Only genuine overflow feeds out. The community benefit costs the homeowner nothing — it comes from energy that would otherwise be unused.
06
Why It Works
Three Motors · Continuous Drive
Three motors inside one shell, offset 120° each. With 3 motors at 3 cog positions each, the cycle count is 9. At no rotation point are all three at dead center — the shell always has drive. The flywheel downstream smooths an already clean torque stream, not raw pulses.
MPPT — Proven Charge Technology
Maximum Power Point Tracking is the standard in solar installations for a reason. It continuously optimizes the charge rate regardless of generator output variation — the same benefit applies here.
48V — Maximum Compatibility
48V is the established standard for residential battery storage. Widest selection of BMS, inverters, and monitoring equipment. Lower current than 12/24V for the same power — less heat, thinner wire, better efficiency.
Storage as Resilience, Not Just Capacity
The battery bank is not just an energy reservoir — it is a mechanical failure buffer. Any PMM maintenance window becomes a planned event rather than an emergency. The home never loses power during service.
No Combustion. No Fuel. No Emissions.
The drive source is permanent magnet — no combustion, no fuel supply, no emissions, no noise. The storage and inverter stages are standard grid-tie equipment. The entire system runs on established, available components.
Complements Existing Solar
Where solar is already installed, this fills the night gap rather than duplicating daytime generation. The two systems are complementary — solar owns the day, this owns the night. Together they approach continuous renewable coverage.
CYR Technologies — Chicago, IL
Triple-Motor PMM Grid-Tie & Backup Storage
