Raspberry Pi CM5 TV Stick Lite
A compact CM5 carrier board that plugs directly into HDMI
mbsmbs
The Raspberry Pi CM5 TV Stick is a carrier that plugs directly to HDMI port. Perfect for Kodi, RetroPie, or just using a Pi attached directly to a monitor or TV for any use case. Board specs: Compatible with Raspberry Pi CM5 Lite and eMMC variants HDMI plug Micro SD card connector USB-C connector for data/power Two USB3.0 USB-A connectors IR receiver User button Power button RPI_nBOOT button for CM5 eMMC programming Fan connector Power and Act LEDs
namnam wrote 05/05/2026 at 06:21 point
Great! It available for sell?
mbs wrote 05/05/2026 at 07:09 point
Hi!
The board is available at Makerfabs: https://www.makerfabs.com/raspberry-pi-cm5-tv-stick-lite.html
