Hackaday.io Hackaday.io
Sign up Log in
Raspberry pi 5 Environment sensor: Waveshare Hat
local dashboard to visualize environmental data in real-time on a Pi 5
davchi15davchi15
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
0
1
1
Team (1)
  • davchi15davchi15
Join this project's team
completed project
Software
raspberrypi Pi5 environment sensor environment Waveshare
This project was created on 05/03/2026 and last updated 14 days ago.
Description
Hey everyone, I wanted to build a local dashboard to visualize environmental data in real-time on my Pi 5 using the Waveshare Sensor HAT. Instead of just printing standard outputs to the terminal, I wrote a Python script to pull the raw I2C data and map it to a live UI. It tracks VOCs, UV, Lux, Temp/Humidity, and maps the 9-axis IMU data to show exact spatial orientation (tilt, angular velocity, and total G-force). To calibrate and test the responsiveness, I ran it against a portable heater, a humidifier, and used a match to spike the VOC index. The Deep Dive: If anyone is interested, I also put together a video breaking down the math and physics behind how these specific sensors https://youtu.be/DN9yHe9kR5U The Code: You can grab the Python script and setup instructions here: https://github.com/davchi15/Waveshare-Environment-Hat-
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Python script collecting system info and data from external sensors
Project Owner Contributor
Pi system info and sensor data
pavol-dudakPavol Dudak
The 2018 Hackaday Prize
A low cost system to predict changes in weather and answer your questions about potential volatile patterns.
Storm Watch
brenda-armourBrenda Armour
A data acquisition box that is able to capture and graph data from analogue and digital sensors using a Raspberry Pi
Data Acquisition Box
kevin-kingsburyKevin Kingsbury
Capturing sensor data from hatchery during the hatching of quails.
Hatching of Quails
katarina-zvarovaKatarina Zvarova
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Raspberry pi 5 Environment sensor: Waveshare Hat", please tell us the reason.
Send message
Remove Member
