OrbitFabric
Open-source mission data contracts for small spacecraft: telemetry, commands, payload data, storage intent and downlink assumptions.
0 followers
OrbitFabric is an open-source model-first Mission Data Contract layer for small spacecraft. It keeps mission-data assumptions explicit before documentation, onboard software assumptions, tests and ground-facing artifacts drift apart. Current release: v0.7.0 — Generated Runtime Skeletons: C++17 runtime-facing contract bindings from the validated Mission Model. It is not flight software, OBC firmware, a ground segment, an onboard runtime, a scheduler, a HAL, or a CCSDS/PUS/CFDP implementation.
WHY THIS EXISTS
Small spacecraft projects often accumulate several parallel descriptions of the same mission behavior.
One view may live in documentation, another in onboard software assumptions, another in test scripts, another in generated reports, and another in ground-facing configuration.
OrbitFabric explores whether a small, explicit Mission Data Contract can become a common source of truth for those artifacts.
The goal is not to replace flight software or ground systems.
The goal is to make mission-data assumptions explicit, lintable, documentable, executable in deterministic host-side scenarios and consumable by generated contract-facing artifacts before they become hidden implementation details.
CURRENT STATUS
Current release: v0.7.0 — Generated Runtime Skeletons.
OrbitFabric is currently a pre-1.0 model-first engineering project.
In v0.7.0, Generated Runtime Skeletons means runtime-facing contract bindings.
The current public preview can model:
  • spacecraft structure
  • subsystems
  • modes
  • telemetry
  • commands
  • events
  • faults
  • packets
  • scenarios
  • payload contracts
  • data products
  • storage intent
  • contact windows
  • downlink flow contracts
  • commandability rules
  • autonomous action assumptions
  • recovery intents
  • contract-level mission data flow evidence
  • runtime-facing contract bindings
From the Mission Model, OrbitFabric can currently generate or execute:
  • structural validation
  • semantic linting
  • engineering lint rules
  • payload contract lint rules
  • data product contract lint rules
  • contact/downlink contract lint rules
  • commandability/autonomy contract lint rules
  • command-declared data product effect linting
  • scenario data-flow expectation validation
  • JSON lint reports
  • Markdown documentation
  • deterministic host-side scenarios
  • simulation JSON reports with data_flow_evidence
  • plain-text simulation logs
  • RuntimeContract construction
  • C++17 runtime-facing identifier headers
  • C++17 runtime value enums
  • C++17 static metadata registries
  • C++17 command argument structs
  • C++17 abstract adapter interfaces
  • C++17 host-build smoke validation
Release-specific details are documented in the Project Logs.
WHAT ORBITFABRIC IS NOT
OrbitFabric is not:
  • flight software
  • OBC firmware
  • a flight-ready onboard runtime
  • a hardware abstraction layer
  • a payload driver framework
  • a spacecraft dynamics simulator
  • an orbit propagator
  • an RF/link budget simulator
  • a real contact scheduler
  • a real downlink runtime
  • an onboard storage runtime
  • a live uplink system
  • a command queue
  • a command dispatch runtime
  • an operator console
  • an onboard scheduler
  • an onboard autonomy runtime
  • real FDIR or safing logic
  • a HAL or RTOS abstraction
  • binary serialization
  • a ground segment
  • a replacement for Yamcs, OpenC3 or OpenMCT
  • a replacement for cFS or F Prime
  • a CCSDS/PUS/CFDP implementation
These may become future integration directions or generated artifact targets, but they are not current capabilities.
ROADMAP DIRECTION
Near-term direction:
  • v0.8 — Ground Integration Artifacts
  • v0.9 — Plugin and Extensibility Layer
  • v1.0 — Stable Mission Data Contract
The roadmap remains pre-1.0 and model-first.
OrbitFabric will not jump directly into ground integration before the mission-data chain and runtime-facing contract boundary are explicit enough to generate meaningful artifacts.
  • v0.7.0 — Generated Runtime Skeletons
    Fabrizio Rovelli05/09/2026 at 15:19 0 comments
    OrbitFabric v0.7.0 introduces the first generated runtime-facing contract binding layer.
    This is a significant step, but the boundary is important.
    Generated Runtime Skeletons are not flight software.
    They are not an onboard runtime, not a scheduler, not a HAL, not a command dispatcher and not a command queue.
    They are contract-facing software artifacts derived from the validated Mission Model.
    Why this release matters
    Previous OrbitFabric releases focused on making the mission data chain explicit.
    The project could already describe telemetry, commands, events, faults, payload contracts, data products, storage intent, downlink intent, contact windows, commandability assumptions and end-to-end data-flow evidence.
    v0.7.0 is the first release where that contract becomes directly visible to implementation code.
    The chain now becomes:
    Mission Model
            -> validation and linting
            -> RuntimeContract
            -> generated C++17 contract bindings
            -> host-build smoke validation
            -> user implementation outside generated/
    This is the key shift.
    OrbitFabric is no longer only producing documentation, reports and deterministic scenario evidence.
    It can now generate a software-facing boundary that implementation code may include, compile and implement against.
    RuntimeContract
    v0.7.0 introduces RuntimeContract.
    RuntimeContract is an intermediate model representing the software-facing subset of the validated Mission Model.
    It is the bridge between the declarative mission contract and generated runtime-facing files.
    The generation flow is:
    Mission Model
            -> structural and semantic validation
            -> engineering linting
            -> RuntimeContract construction
            -> profile-specific generator
            -> generated runtime-facing artifacts
    The current generation profile is:
    cpp17
    This is deliberately narrow.
    The goal is not to generate onboard behavior.
    The goal is to expose the validated contract surface in a deterministic software-facing form.
    The new generator command
    The new command is:
    orbitfabric gen runtime examples/demo-3u/mission/
    The default generated output is:
    generated/runtime/cpp17/
    The generated C++17 profile currently emits:
    generated/runtime/cpp17/runtime_contract_manifest.json
    generated/runtime/cpp17/CMakeLists.txt
    generated/runtime/cpp17/include/orbitfabric/generated/mission_ids.hpp
    generated/runtime/cpp17/include/orbitfabric/generated/mission_enums.hpp
    generated/runtime/cpp17/include/orbitfabric/generated/mission_registries.hpp
    generated/runtime/cpp17/include/orbitfabric/generated/command_args.hpp
    generated/runtime/cpp17/include/orbitfabric/generated/adapter_interfaces.hpp
    generated/runtime/cpp17/src/orbitfabric_runtime_contract_smoke.cpp
    These are generated artifacts.
    They are reproducible and disposable.
    User implementation code must live outside generated/.
    What the generated bindings expose
    The generated runtime-facing contract bindings expose several kinds of information.
    Identifier headers provide deterministic strongly typed identifiers for model elements such as:
    ModeId
    TelemetryId
    CommandId
    EventId
    FaultId
    PacketId
    PayloadId
    DataProductId
    StoragePolicyId
    DownlinkPolicyId
    Static registries expose contract metadata such as model IDs, symbol names, value types, units, command targets, event severities, fault metadata and data product attributes.
    Command argument structs expose the declared shape of command arguments.
    For example:
    struct PayloadStartAcquisitionArgs {
        std::uint16_t duration_s;
    This struct defines the contract-facing command argument shape.
    It does not parse packets.
    It does not validate permissions.
    It does not enqueue commands.
    It does not execute the command....
  • v0.6.0 — End-to-end mission data flow evidence
    Fabrizio Rovelli05/08/2026 at 21:32 0 comments
    OrbitFabric v0.6.0 adds the first end-to-end Mission Data Flow Evidence slice.
    The previous logs walked through the individual contract layers:
    payload contracts,
    data products,
    storage intent,
    downlink intent,
    contact windows,
    downlink flows,
    commandability rules,
    and autonomy assumptions.
    v0.6.0 connects those layers into one inspectable evidence chain.
    It does not make OrbitFabric a runtime.
    It makes the declared mission-data path traceable.
    From contract layers to evidence
    Until now, each release added another part of the Mission Data Contract.
    v0.3.0 made data products and storage intent explicit.
    v0.4.0 connected data products to contact windows and downlink flow contracts.
    v0.5.0 added commandability and autonomy contracts, making command sources, command rules and recovery assumptions visible.
    v0.6.0 adds the next question:
    if a command is expected to produce mission data, can OrbitFabric trace that declared data product through storage intent, downlink intent, eligible downlink flow, contact window assumption and scenario evidence?
    The contract chain now becomes:
    command expected effect
            -> data product
            -> storage intent
            -> downlink intent
            -> eligible downlink flow
            -> matching contact window
            -> scenario evidence
            -> generated documentation
            -> JSON report evidence
    This is the first end-to-end evidence slice in OrbitFabric.
    What changed in v0.6.0
    v0.6.0 introduces:
    • command-declared data product effects
    • command linting for expected data product references
    • scenario data-flow assertions
    • scenario reference validation for data-flow expectations
    • deterministic data-flow evidence recording during simulation
    • JSON simulation reports with data_flow_evidence
    • generated data_flow.md documentation
    • a dedicated data-flow documentation generator
    • a new demo scenario: payload_data_flow_evidence.yaml
    The important part is not that another generated file exists.
    The important part is that the Mission Model can now describe and check a declared path from command intent to mission-data movement assumptions.
    Command-declared data product effects
    Commands may now declare that they are expected to produce or trigger one or more data products.
    A shortened example looks like this:
    expected_effects:
      data_products:
        - payload.radiation_histogram
    This makes the command-to-data-product relationship explicit.
    If a command claims to produce a data product that is not declared in data_products.yaml, OrbitFabric should fail early.
    That is where the new command diagnostics are useful:
    OF-CMD-008
    OF-CMD-009
    The intent is simple:
    a command expected effect should not silently point to a non-existing mission-data object.
    Scenario data-flow assertions
    Scenarios can now assert that a declared data-flow path exists.
    expect:
      data_flow:
        data_product: payload.radiation_histogram
        triggered_by_command: payload.start_acquisition
        storage_intent_declared: true
        downlink_intent_declared: true
        eligible_downlink_flow: science_next_available_contact
        contact_window: demo_contact_001
    This does not execute real storage.
    It does not execute real downlink.
    It asks whether the declared Mission Model contains a coherent contract-level path for that data product.
    The scenario loader validates references before execution.
    The new scenario diagnostics cover missing or invalid references in data-flow expectations:
    OF-SCN-014
    OF-SCN-015
    OF-SCN-016
    OF-SCN-017
    What the simulator records
    During deterministic host-side scenario execution, OrbitFabric records contract-level data-flow evidence when an accepted command declares data product effects.
    The demo scenario exercises a chain like this:
  • v0.5.0 — Commandability and autonomy contracts
    Fabrizio Rovelli05/07/2026 at 22:08 0 comments
    OrbitFabric v0.5.0 adds the first Commandability and Autonomy Contract slice.
    The previous logs focused on the mission-data chain:
    what the spacecraft produces,
    where data products are intended to be stored,
    how they become eligible for downlink,
    and which declared contact assumptions support that path.
    v0.5.0 adds the next contract question:
    how are commands intended to be used, constrained, confirmed, and referenced by declared autonomous or recovery assumptions?
    This is still contract-level modeling.
    It is not command execution.
    Why commandability belongs in the contract layer
    A small spacecraft mission does not only need to describe telemetry, data products, storage intent and downlink assumptions.
    It also needs to describe how commands are expected to be used.
    For example:
    Can this command be dispatched from ground?
    Does it require a contact assumption?
    Which mode should allow it?
    Does it require explicit confirmation?
    What event or telemetry evidence is expected after it runs?
    Can an autonomous recovery assumption dispatch a command?
    Which fault should lead to which recovery intent?
    Those are not only runtime questions.
    They are also mission-data contract questions.
    If a payload acquisition command exists, but nobody declares when it is commandable, which source may dispatch it, what confirmation is expected, or how recovery should stop it during a battery fault, then part of the mission behavior is still implicit.
    OrbitFabric v0.5.0 tries to make that implicit layer visible.
    What v0.5.0 adds
    The new optional domain is:
    mission/commandability.yaml
    It can describe:
    • command sources
    • command confirmation intent
    • recovery intents
    The chain now extends one step further:
    Payload Contract
            -> Data Product Contract
            -> Storage Intent
            -> Downlink Intent
            -> Contact Window Assumption
            -> Downlink Flow Contract
            -> Commandability and Autonomy Contract
    This does not turn OrbitFabric into a command system.
    It adds another declared consistency layer.
    Example from the demo mission
    A shortened excerpt from the synthetic demo mission looks like this:
    commandability:
      sources:
        - id: ground_operator
          type: ground
          requires_contact: true
          contact_profile: primary_ground_contact
        - id: onboard_autonomy
          type: autonomous
          requires_contact: false
      rules:
        - id: payload_start_ground_rule
          sources:
            - ground_operator
          allowed_modes:
            - NOMINAL
          confirmation: required
          expected_events:
            - payload.acquisition_started
          expected_effects:
            telemetry:
              payload.acquisition.active: true
            mode_transition:
              to: PAYLOAD_ACTIVE
      autonomous_actions:
        - id: stop_payload_on_battery_low
          trigger:
            fault: eps.battery_low_fault
          dispatches:
            command: payload.stop_acquisition
            source: onboard_autonomy
          expected_events:
            - payload.acquisition_stopped
      recovery_intents:
        - id: payload_battery_low_recovery
          target_mode: DEGRADED
          commands:
            - payload.stop_acquisition
    This is intentionally minimal.
    It is not a real operator...
  • New public minislices: from generic CubeSat to communications-oriented mission data contracts
    Fabrizio Rovelli05/06/2026 at 22:58 0 comments
    Today I added a new set of public minislice examples to OrbitFabric.
    The goal was to move beyond a single synthetic demo and show how the same model-first contract approach can be specialized into several small, recognizable CubeSat-style mission data patterns.
    The new examples are:
    examples/university-cubesat-minislice/
    examples/oresat-inspired-minislice/
    examples/finch-inspired-minislice/
    examples/spacelab-inspired-communications-minislice/
    Each minislice is intentionally small, public-material-derived or synthetic, and focused on OrbitFabric’s core scope:
    telemetry
    commands
    events
    faults
    modes
    packets
    payload contracts
    data products
    contact windows
    downlink flows
    scenario evidence
    OrbitFabric is still not flight software, not an OBC firmware, not a dynamic simulator and not a ground segment.
    These examples are contract-layer demonstrations.
    1. Generic university CubeSat minislice
    The first example is the baseline:
    It models a generic university CubeSat mission-data chain:
    payload data generated
    → low-power warning
    → constrained low-rate contact
    → health and critical data prioritized
    → payload data partially downlinked
    → remaining data kept pending onboard
    → scenario evidence explains the result
    This example is fully synthetic and acts as the clean baseline for the more specific public-inspired examples.
    2. OreSat-inspired minislice
    The second example is:
    This is a public conceptual demo inspired by the OreSat ecosystem.
    It focuses on a CubeSat-style pattern involving:
    beacon / housekeeping priority
    power-aware operations
    C3-style command and data handling
    CFC-style payload data
    constrained downlink
    retained payload backlog
    It is not an official OreSat model. It is not endorsed by OreSat, PSAS or Portland State University. It is not a conversion of OreSat configs or CANopen object dictionaries. It does not replace OreSat software, OLAF, Yamcs, configs or ground tools.
    The point is narrower: use public inspiration to test whether OrbitFabric can express a realistic constrained-downlink mission data contract.
    3. FINCH-inspired minislice
    The third example is:
    This one is focused on an imaging-payload workflow.
    It models:
    acquisition parameters loaded
    → OBC schedules image acquisition
    → ADCS readiness checked
    → payload camera readiness checked
    → image acquisition
    → data compression
    → constrained downlink
    → compressed image data partially pending
    → scenario evidence records the outcome
    It is not an official FINCH model. It is not endorsed by UTAT Space Systems, the University of Toronto Aerospace Team or the University of Toronto. It is not a conversion of FINCH architecture diagrams. It does not replace FINCH firmware, data-processing tools or systems-engineering tools.
    The purpose is to show a different vertical slice: acquisition readiness, payload data generation, compression and partial downlink.
    4. SpaceLab-inspired communications minislice
    The fourth example is:
    This one is communications-oriented rather than payload-oriented.
    It is inspired by public SpaceLab UFSC / FloripaSat / GOLDS-UFSC material and focuses on a compact TT&C / OBDH data-flow contract:
    periodic beacon available
    → synthetic ground contact starts
    → TT&C receives an abstract data-request command
    → OBDH accepts the request
    → OBDH selects stored telemetry/data frames
    → OBDH packages frames for downlink
    → beacon and critical housekeeping are prioritized first
    → requested frames are partially downlinked
    → remaining frames stay pending onboard
    → decoder evidence records partial completion
    It is not an official SpaceLab, FloripaSat or GOLDS-UFSC model. It is not endorsed by SpaceLab UFSC or UFSC. It is not a claim that SpaceLab uses OrbitFabric. It is not a conversion of FloripaSat architecture, firmware, packet formats...
  • v0.4.0 — Contact windows and downlink flow contracts
    Fabrizio Rovelli05/05/2026 at 12:51 0 comments
    OrbitFabric v0.4.0 extends the mission-data chain beyond payloads, data products and storage intent.
    This release is about contact and downlink assumptions.
    What v0.4.0 adds
    Before this release, OrbitFabric could already model a chain such as:
    Payload Contract
            -> Storage Intent
            -> Downlink Intent
    With v0.4.0, that chain becomes:
    Payload Contract
            -> Storage Intent
            -> Downlink Intent
    This does not make OrbitFabric an operational downlink system.
    It makes declared assumptions explicit.
    The boundary: contract, not runtime
    This is an important boundary.
    OrbitFabric v0.4.0 does not:
    • compute real orbital passes
    • schedule real ground contacts
    • simulate RF links
    • execute downlink
    • replace a ground segment
    The v0.4.0 model works at contract level.
    It asks a narrower question:
    if a mission declares that a data product should be stored and later downlinked, are the declared contact and downlink assumptions coherent enough to be reviewed, linted and documented?
    What contacts.yaml can express
    The optional contacts.yaml domain can describe:
    • contact profiles
    • link profiles
    • contact windows
    • declared contact capacity
    • downlink flow intent
    • eligible data products
    This gives the Mission Model a way to express questions such as:
    • which contact assumption is being used?
    • which link profile applies?
    • what capacity is declared for that window?
    • which data products are eligible?
    • which downlink flow references them?
    • does the declared flow reference valid mission objects?
    For small spacecraft projects, those assumptions often exist anyway.
    They may live in an operations note, a spreadsheet, a test script, a ground-facing configuration file, or simply in the head of the person who planned the first demo pass.
    OrbitFabric v0.4.0 tries to move those assumptions into the Mission Data Contract.
    contact_windows:
      - id: demo_contact_001
        link_profile: uhf_downlink_nominal
        start: "2026-01-01T00:00:00Z"
        duration_seconds: 600
        assumed_capacity_bytes: 512000
    downlink_flows:
      - id: science_next_available_contact
        queue_policy: priority_then_age
        eligible_data_products:
    This is intentionally simple.
    What this example is not
    The example is not:
    • a real pass
    • based on TLE propagation
    • derived from a ground station network
    • a real RF budget
    • an operational schedule
    It is a declared contract-level assumption.
    That assumption is useful because it connects the data product model to the downlink model.
    The demo data product payload.radiation_histogram is produced by a synthetic payload contract, has storage intent, has retention intent, has overflow policy and has downlink intent.
    The v0.4.0 contact/downlink model then gives that data product a declared path toward downlink eligibility.
    What gets checked
    At this stage, the value is consistency.
    OrbitFabric should fail early when:
    • a downlink flow references an unknown data product
    • a contact window references an unknown profile
    • a link profile or contact profile is missing
    • a mission claims that a data product is intended for downlink but no visible contract-level assumption explains how it becomes eligible
    The generated contacts.md artifact is therefore not just documentation.
    It is a reproducible view of declared downlink assumptions.
    As usual in OrbitFabric, generated artifacts are not the...
  • Payload contracts, data products and storage intent
    Fabrizio Rovelli05/05/2026 at 12:50 0 comments
    In OrbitFabric, a payload is not treated only as something that produces telemetry.
    A payload may also produce mission data products.
    That distinction matters.
    Payload data is not just telemetry
    Telemetry is usually about observability: state, health, counters, measurements, events and operational status.
    Mission data products are different.
    They are the objects the mission wants to preserve, reason about, store and eventually downlink.
    For a small spacecraft project, that difference can easily become blurred.
    A payload may expose telemetry.
    It may accept commands.
    It may raise events.
    It may enter lifecycle states.
    It may generate faults.
    It may produce histograms, images, files, packets, measurements or other mission-specific outputs.
    If those relationships are only described informally, integration debt appears quickly.
    The onboard software may know one version.
    The payload documentation may describe another.
    The test scenario may assume another.
    The storage plan may evolve separately.
    The downlink plan may be discussed later.
    The generated documentation may lag behind.
    OrbitFabric tries to make that chain explicit.
    The contract chain
    The current v0.4.0 model includes optional Payload Contracts and Data Product Contracts.
    A payload contract describes mission-facing payload behavior at contract level.
    A data product contract describes a mission-data object produced by a payload or subsystem.
    The intended chain is:
    Payload Contract
            -> declared payload behavior
            -> Storage Intent
            -> Retention Intent
            -> Overflow Policy
            -> Downlink Intent
    This does not describe payload firmware.
    It does not describe payload drivers.
    It does not describe hardware buses.
    It does not simulate the physical payload.
    It describes the mission-facing contract.
    Payload contract excerpt
    The synthetic demo mission includes a clean-room IOD payload contract.
    A shortened excerpt looks like this:
    payloads:
      - id: demo_iod_payload
        subsystem: payload
        profile: iod
        lifecycle:
          initial_state: READY
          states:
            - OFF
            - READY
            - ACQUIRING
            - FAULT
        telemetry:
          produced:
            - payload.acquisition.active
        commands:
          accepted:
            - payload.start_acquisition
        events:
          generated:
    This tells the model which mission-facing objects belong to that payload contract.
    It does not tell OrbitFabric how the payload firmware is implemented.
    Data product excerpt
    The same demo mission declares one synthetic payload data product.
    data_products:
      - id: payload.radiation_histogram
        producer: demo_iod_payload
        producer_type: payload
        type: histogram
        estimated_size_bytes: 4096
        priority: high
        storage:
          class: science
          retention: 7d
          overflow_policy: drop_oldest
        downlink:
          policy: next_available_contact
    This is not a real payload product.
    It is a clean-room demo object used to exercise the model.
    The important point is not the histogram itself.
    The important point is that the data product has declared engineering intent:
    • who produces it
    • what type of product it is
    • how large it is expected to be
    • how important it is
    • where it is intended to be stored
    • how long it should be...
  • From mission model to reproducible artifacts
    Fabrizio Rovelli05/05/2026 at 12:48 0 comments
    The core idea behind OrbitFabric is simple.
    The Mission Model should be the source of truth.
    Not the generated documentation.
    Not the test log.
    Not a hand-written table.
    Not a partially outdated diagram.
    The model comes first
    In many small spacecraft projects, mission data definitions start clean and then drift.
    Telemetry is described in one place.
    Commands are implemented somewhere else.
    Events and faults are listed in a document.
    Payload behavior is captured in tests.
    Storage assumptions live in a planning sheet.
    Downlink assumptions are discussed during integration.
    Ground-facing artifacts are created later, often manually.
    OrbitFabric explores a different flow.
    The model comes first.
    The current demo mission lives under:
    It contains structured YAML files for the mission contract:
    ├── spacecraft.yaml
    ├── subsystems.yaml
    ├── modes.yaml
    ├── telemetry.yaml
    ├── commands.yaml
    ├── events.yaml
    ├── faults.yaml
    ├── packets.yaml
    ├── policies.yaml
    ├── payloads.yaml
    ├── data_products.yaml
    └── contacts.yaml
    Those files are not intended to be a pretty configuration layer over an existing implementation.
    They are intended to make mission-data assumptions explicit before they become scattered across code, tests, documents and ground tooling.
    The current v0.4.0 flow
    The current v0.4.0 flow is:
    Mission Model YAML
            -> structural validation
            -> semantic lint
            -> engineering lint
            -> JSON lint report
            -> generated Markdown documentation
            -> scenario validation
            -> deterministic scenario execution
            -> simulation report
            -> simulation log
    That matters because every generated artifact is derived from the same declared contract.
    If a telemetry point is renamed, the documentation should not silently keep the old name.
    If a scenario references a command that does not exist, that should fail early.
    If a payload data product references an invalid producer, that should be detected.
    If a downlink flow references an unknown contact profile or an ineligible data product, that should not remain a hidden integration assumption.
    CLI flow
    The current CLI reflects this model-first flow.
    Typical local checks are:
    orbitfabric lint examples/demo-3u/mission/
    orbitfabric gen docs examples/demo-3u/mission/
    orbitfabric sim examples/demo-3u/scenarios/battery_low_during_payload.yaml
    Generated documentation
    The generated documentation currently includes mission-facing artifacts such as:
    generated/docs/
    ├── telemetry.md
    ├── commands.md
    ├── events.md
    ├── faults.md
    ├── modes.md
    ├── packets.md
    ├── payloads.md
    ├── data_products.md
    └── contacts.md
    These files are generated outputs.
    They are useful for review, discussion and integration.
    But they are not the source of truth.
    The source of truth remains the Mission Model and the scenario definitions.
    Scenario evidence
    The same applies to simulation reports and logs.
    For example, the synthetic demo scenario battery_low_during_payload exercises a declared chain:
            -> payload.acquisition_started
            -> mode transition into PAYLOAD_ACTIVE
            -> battery voltage degradation
            -> eps.battery_low
            -> mode transition into DEGRADED
            -> automatic payload.stop_acquisition dispatch
            -> payload.acquisition_stopped
            -> scenario passed
    This is not a physics simulation.
    It is not a flight software runtime.
    It is not running on...
  • Why OrbitFabric exists
    Fabrizio Rovelli05/05/2026 at 12:45 0 comments
    Small spacecraft projects rarely fail because nobody wrote a YAML file.
    They fail, or at least become painful to integrate, when several different descriptions of the same mission behavior start drifting apart.
    The problem: mission-data drift
    One description lives in the mission document.
    Another one lives in onboard software assumptions.
    Another one lives in test scripts.
    Another one lives in generated reports.
    Another one lives in ground-facing configuration.
    Another one may exist only in somebody's head.
    Telemetry, commands, events, faults, packets, payload outputs, storage expectations and downlink assumptions are often treated as separate artifacts.
    That separation is where integration debt starts.
    What OrbitFabric tries to do
    OrbitFabric exists to explore a different approach:
    define the mission data contract once,
    validate it,
    generate documentation from it,
    run deterministic host-side scenarios from it,
    and later use it as the basis for integration artifacts.
    The important point is not the file format.
    The important point is the engineering boundary.
    What does the mission claim to produce?
    What commands are expected?
    What events and faults can be raised?
    What data products exist?
    Where are they intended to be stored?
    When should they become eligible for downlink?
    Which contact assumptions are being used?
    In a small spacecraft project, those questions should not be answered differently by the README, the onboard code, the test scripts and the ground configuration.
    OrbitFabric is an attempt to make those assumptions explicit early, before they become hidden integration debt.
    Current v0.4.0 scope
    The current v0.4.0 release focuses on the contract layer.
    It can model:
    • subsystems
    • modes
    • telemetry
    • commands
    • events
    • faults
    • packets
    • payload contracts
    • data products
    • storage intent
    • contact windows
    A simplified view of the current idea is:
    Mission Model
            -> validation
            -> lint report
            -> simulation log
    Optional Payload Contract Model
            -> payload reference validation
            -> payload lifecycle validation
            -> payload documentation generation
    Optional Data Product Contract Model
            -> producer reference validation
            -> storage intent validation
            -> downlink intent validation
            -> data product documentation generation
    Optional Contact and Downlink Contract Model
            -> contact profile validation
            -> link profile validation
            -> contact window validation
            -> downlink flow consistency validation
            -> contact/downlink documentation generation
    What OrbitFabric is not
    The current project is intentionally narrow.
    OrbitFabric is not:
    • flight software
    • OBC firmware
    • a ground segment
    • a replacement for cFS, F Prime, Yamcs, OpenC3 or OpenMCT
    Those may become future integration directions or generated artifact targets, but they are not current capabilities.
    Why the boundary matters
    This is still a pre-1.0 engineering project.
    The examples are synthetic and clean-room.
    The current demo mission is not a real spacecraft.
    The contact windows are declared assumptions, not real orbital pass predictions.
    The downlink flow model is a contract-level consistency layer, not an operational downlink runtime.
    That boundary matters.
    OrbitFabric should be judged as a small open-source attempt to reduce drift between mission design, software assumptions,...
View all 8 project logs
