Homemade ECG With Discrete Analog Front End
An ECG recorder built from discrete components, with FPGA-based digital filtering and Pan–Tompkins R-wave detection.
0 followers
A single-channel biopotential recorder designed for educational use. The analog front end is built entirely from discrete components for amplification and initial filtering. On the digital side, a Tang Nano 9K FPGA (GW1NR-9) handles ADC acquisition, digital filtering — 0.67 Hz HPF, selectable 40/100/200 Hz LPF, and an optional 50 Hz notch — along with Pan–Tompkins R-wave detection and a DAC output for waveform debugging. An ESP32-S3 takes care of system control, the user interface, and data export in CSV and BDF formats. More details available on GitHub.
  • Analog front end built from discrete components — no monolithic ASIC, making it well-suited for teaching and demonstration
  • Equivalent input noise density of 18.8 nV/√Hz; 266 nV RMS over a 200 Hz bandwidth
  • Bandwidth 0.05–200 Hz; high-pass cutoff switchable between 0.05 Hz and 1.5 Hz; multiple digital filter modes available
  • Isolated power supply for common-mode interference rejection
  • Gain of 61.78 dB (×1228), Full-scale input of 2 mVpp
  • FPGA-based FIR/IIR filtering and Pan-Tompkins heart rate detection
hardware.zip
x-zip-compressed - 5.10 MB - 05/06/2026 at 15:33
Download
firmware.zip
x-zip-compressed - 34.05 MB - 05/06/2026 at 15:37
Download
LICENSE.md
markdown - 1.74 kB - 05/06/2026 at 15:39
Download
  • 1 × main board
  • 1 × AFE module
  • 1 × isolated power supply module
  • 1 × Tang Nano 9K development board
  • 1
    Step 1
    Go to the `hardware/` directory, order PCBs for each of the three subdirectories, and purchase and solder components according to the EasyEDA Pro projects.
  • 2
    Step 2
    Go to the `firmware/` directory and flash the FPGA and MCU firmware following the flashing guide.
  • 3
    Step 3
    Fabricate electrodes: wet electrodes are recommended for better contact impedance. See Section 3.3.3 — Practical Electrodes for details.
View all 6 instructions
