Hello everyone, today I'll be unboxing and showcasing the FNIRSI DPS-150, a lightweight, high-performance, programmable, digital DC power supply with adjustable output, which you can pick up for an incredibly great price. The unit features a Type-C input and multiple power supply modes, allowing precise adjustment of voltage from 0 to 30V and current from 0 to 5A. Inside the box, you'll find the main unit, two alligator clip leads with banana plugs, a USB-A to Micro USB power cable, and a user manual. On top of that, the device comes with plenty of smart features that you're sure to love.
Is this the best budget lab power supply?
Video: https://youtu.be/xa1ZhUgL_6Y
AliExpress: https://s.click.aliexpress.com/e/_c3EPIPtP
Turning It On
The LCD screen tilts 90° and shows both numerical readings and graphs for monitoring purposes. The front-facing buttons allow you to navigate and adjust various settings. These two ports are where the banana plugs are inserted. This rotating knob is to ajust voltage and amps. This is the power button used to activate the output ports.
On the back, you’ll find the MicroUSB, USB-C, and barrel jack ports for powering the unit.
Now, let's connect the USB-C cable and power on the unit. The unit can be powered by a power bank, DC adapter, or a PD/QC fast charger. The unit accepts PC, QC, and DC inputs, features programmable outputs, and includes six preset voltage and current settings.
At the top of the screen, the input voltage is shown. The device is a step-down converter, so it can reduce the input voltage to any lower voltage of your choice.
On the left, the output voltage, output current, and output power are displayed in larger text, while the preset voltage and current appear in smaller text.
On the right, you’ll find the energy consumption, the total time the unit has been powered on, and the presets listed at the bottom.
The red "STOP" indicator next to the operating temperature means the unit is in standby mode and not currently providing any output. Pressing the button on the right activates the output, at which point "STOP" changes to "RUN," and the banana plug holders light up.
Pressing the double arrow button allows you to adjust the output voltage and current in real time using the rotary knob.
Long pressing the double arrow button allows you to toggle between graph and normal mode.
To change a preset: hold the "M" button, select a preset, set voltage/current and save. The unit offers 6 preset modes.
Pressing the "Home" button opens the internal configuration menu, where you can adjust settings such as Language, Theme, Brightness, Volume, Overvoltage, Overcurrent, Overpower, Overtemperature, and all other parameters.
Let's perform a quick test with a multimeter to verify that the output matches the selected voltage. As you can see, the multimeter reads approximately the same voltage as our selected output voltage. Great - it works!
Features & Specs
Here are the main product specifications of this unit displayed on-screen. The product operates in "step-down mode", so ensure that the input voltage is always higher than the output voltage.
The unit offers over voltage, under voltage, over current, over temperature, short circuit, reverse input and out protection.
For a complete list of specifications and features, be sure to visit the official website. The link is in the description below.
Warranty
This item is built to last; with the right handling, it will serve you well for years to come. For added peace of mind, it includes a 30-day return and refund guarantee when you purchase it directly from FNIRSI.com, you'll also receive a full 2-year warranty and lifetime technical support from the manufacturer.
Email: service@fnirsi.com / info@fnirsi.com
How To Order
The FNIRSI DPS-150 can be purchased through their official website or via AliExpress; both links are provided in the description below. When ordering, you...
Hulk
sadeed
icstation
W4KRL
