Building a hardware ternary computer. Help wanted!
I will build a ternary computer, where a positive current is considered 1 and a negative current is considered -1. But I can't manage both 1
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I’m planning to build a ternary computer where a +- wiring sequence is assigned a value of 1 and a -+ wiring sequence is assigned a value of -1. Theoretically, I plan to treat AND as: 1 + 1 = 1 -1 + -1 = -1 everything else = 0 and NOT as: 1 + 1 = -1 -1 + -1 = 1 1 + 0 = 1 -1 + 0 = -1 everything else = 0 I intended to connect AND on the left and NOT on the right to reproduce one-digit + one-digit operations, but I simply cannot reconcile the fact that 1 + 1 = 1 and 1 + 0 = 1 at the same time. If you could lend me a hand, I would appreciate it. ※The goal is to build an operating system
