SPECS
- 100 mm diameter, 1.6 mm thick PCB (13 mm height with batteries)
- 55 green SMD LEDs (1608 package)
- 33⅓ / 45 rpm via slide switch
- 2x AAA batteries (~19h at 33⅓, ~25h at 45 rpm)
- 35 g without batteries
- 1.2V rechargeable batteries (NiMH etc) are not recommended due to insufficient voltage
NOTE
The battery holders add 13 mm of height. Not compatible with some linear tracking turntables.
IDEAL FOR
- Vinyl enthusiasts who want precise speed calibration
- Turntable setup and maintenance
- Audio engineers and hi-fi hobbyists
- DJs looking for a visual light effect on the platter
Available as an assembled unit on Etsy:
https://elehobica.etsy.com
