IMAROV only has 4 thrusters (4 degrees of freedom). I used a mixture of BlueRobotics and other components:
  • single BlueRobotics enclosure (D=75mm L=300mm)
  • 4 x APISQUEEN X1 thrusters with 45A bi-directional ESCs
  • BlueRobotics Navigator / RPi 4
  • Fathom X tether and interface boards
  • BlueRobotics Low-Light HD USB Camera
  • BlueRobotics Bar30 depth sensor
  • gimble servo with custom mount
  • custom built 8x18650 battery back (4S2P)
  • alum. and PLA 3D printed frame
The challenge was fitting all the components into the small enclosure, but the system works well based on initial pool testing (yet to be ocean tested). I am using BlueRobotics Cockpit software with a game controller on the topside laptop. I designed the alum. frame and thrusters to detach easily when the enclosure needs to be opened (for battery change etc.) It only weights a couple of kg.
Blue Robotics Parts List
Item
Quantity
Code
Cost (USD)
Acrylic Enclosure (75mm x 240mm)
1
BR-102649-240
180
Acrylic dome
1
BR-101059
32
Alum. flange with locking cord
2
BR-100647
76
Alum. end cap (7 x M10 holes)
1
BR-100949-007
18
Tether - 1 twisted pair (50m)
1
BR-100638
250
Fathom X interface boards (pair)
1
BR-100178
280
Navigator flight controller
1
BR-100367
220
Raspberry Pi 4 2GB
1
BR-100950
65
5V 6A Power supply
1
BR-100869
32
Low light HD USB camera
1
BR-100126
120
Penetrator 4.5mm HC
5
BR-100870-145
65
Bar30 depth sensor
1
BR-100586
90
Pressure relief valve
1
BR-100804
32
1460
Thrusters/ESCs
Item
Quantity
APISQUEEN X1 Thruster CCW
2
APISQUEEN X1 Thruster CW
2
APISQUEEN 45A bi-directional ESC
4
Other Parts
Item
Dimensions
Quantity
Purpose
Aluminium flat plate
2
Thruster ribs
2
Cable lugs
Aluminium C channel
1
Ballast track
Aluminium C channel
2
Hz thruster lock
SS wire rope
D=2mm L=350mm
1
Carry handle
SS swages
2
Carry handle
SS thimbles
2
Carry handle
SS Shackle
1
Tether strain safety
SS thimbles
1
Wago 4MM 10way Splicing connector with levers
2
+/- to ESCs
Steel thread (M4)
L=155mm
2
Battery holder
Nuts (M4)
8
Battery holder
Nickel strip
L=300mm
Battery holder
Adhesive backed rubber
Battery holder
20A blade fuse
1
Battery holder
Fuse holder
1
Battery holder
Amass connector (male & female)
1
Battery holder
18650 Lithium battery
8
Battery holder
Steel rod
D=1.5mm L=75mm
1
Rubber sheet or roll
1.5 thick
Glued to inside of enclosure brackets
Consumables
Item
Heat shrink
Solder
Polyurethane adhesive
