What It Actually Does
An alien fleet travels through an elongated wormhole toward your base. The enemies appear one by one from the far end of the LED strip, marching steadily toward you. Your job is to shoot them with the right colour laser before they reach the end.
You have three laser buttons: red, green and blue. The trick is that combinations work too. Press red and green simultaneously and you fire yellow. Green and blue gives cyan, red and blue gives magenta, all three gives white. No controller with forty buttons. Three buttons, seven colours, one increasingly panicking player.
The Enemies
Asteroids are single pixels in a primary colour: red, green or blue. One button, one shot, one point. Perfect for a four-year-old. They will feel like a hero.
Planets are single pixels in mixed colours: yellow, cyan or magenta. Now you need to press two buttons at the same time. This is where younger siblings start losing to older siblings and nobody is happy about it.
Stars are white pixels that always appear last in a wave. All three buttons simultaneously. Three points. The button LEDs flash as a victory celebration, which is objectively the best part of the game.
Meteors are four consecutive pixels of the same colour, noticeably dimmer than single invaders, and they get dimmer the more damage they take. Each pixel has 2 HP and you must work from the front pixel backward. Eight hits to destroy, four points maximum. Missing a shot on a meteor does not just waste your time: the wrong-colour bullet joins the front of the wave, making the problem longer. Consequently, the family member who keeps missing the meteor becomes very popular.
The Bosses
Three boss types appear at higher levels, after the wave is cleared. Bosses advance from the far end of the strip and fire back. Miss one incoming projectile and it is immediately game over.
The Rampart crawls slowly toward you, fires projectiles in colours that often don't match its front segment (rude), and enters rage mode if you hit it with the wrong colour three times in a row, unleashing a rapid burst that has ended more than one promising run.
The Sentinel stops at three fixed positions, charges up with a pulsing warning, then fires a barrage of projectiles. After the barrage, its segments become vulnerable for a limited time. The segments you don't destroy in time make the next barrage longer. It is the closest a strip of LEDs can get to being passive-aggressive.
The Prism has fifteen segments in random mixed colours and never stops moving. Twice during the fight all segments turn white and it becomes briefly invulnerable, then recolours randomly and immediately fires a burst in mixed colours. This is the hard boss. Children who reach the Prism should be treated with respect.
What Makes This Different
It fits in a living room. The strip is two metres long and hangs on a wall, lies on a table or drapes over a shelf. No dedicated game room required.
No noise. No speakers, no sound effects, no eight-bit music loop that lodges in your brain for three days. A normal conversation remains entirely possible. You might even enjoy it.
No apps, no WiFi, no Bluetooth, no 3D-printed parts. Plug it in, play it. The entire interface is three coloured buttons with built-in LEDs, one black confirm button and a six-digit display. Anyone who has ever pressed a button can figure it out within thirty seconds.
Selectable level range. You choose a start level and a stop level before each game. For the youngest children: levels 1 to 2, primary colours only, no shooting back. For older kids: 3 to 5, mixed colours, meteors, one boss. For the household's self-proclaimed gaming expert: 6 to 9, fast waves, complex meteors, all three bosses. Or play all nine levels in one sitting if everyone has time and nobody needs to go to bed.
Nine Levels, Fully Configurable
Each level is defined by a ten-column table in the firmware: gap between waves, number of waves, asteroid count, star count, planet count, meteor count, mixed-colour meteor count, wave speed, boss type and boss difficulty. Every value is a number in a array. If you want a level with twenty asteroids and no boss, change two numbers. If you want three waves of fast mixed meteors followed by a hard Prism, also two numbers. The levels ship with sensible defaults but the table is right at the top of the file, clearly commented, and deliberately inviting.
// ── Players
#define NUM_PLAYERS_MAX 7 // max selectable players (fits in 1 byte bitmask)
const char PLAYER_NAMES[NUM_PLAYERS_MAX][7] = {
"Juno ", "SaaR ", "ANNE ", "SPRITE", "BLAST ", "TITAN ", "GAIA ",
// Columns:
// gap = off-screen pixels between waves (not before the first wave)
// waves = number of waves per level (0 = boss-only, skip wave phase entirely)
// ast = asteroids (R/G/B, 1 button, +1 pt each)
// star = stars (white, 3 buttons, +3 pt, always last in wave)
// planet = planets (Y/C/M, 2 buttons, +2 pt each)
// meteor = primary-colour meteors (METEOR_WIDTH px, METEOR_HP per px, +1 pt/px)
// cmet = mixed-colour meteors
// speed = wave speed (1=slow, 2=medium, 3=fast)
// bTyp = boss type (0=none, 1=Rampart, 2=Sentinel, 3=Prism)
// bDif = boss difficulty (1=easy, 2=medium, 3=hard; 0 is invalid, clamped to 1)
const uint16_t LEVELS[NUM_LEVELS][10] = {
// gap waves ast star pln met cmet spd bTyp bDif
{ 10, 1, 10, 0, 0, 0, 0, 1, 0, 0 }, // level 1 basics only
{ 10, 2, 10, 0, 0, 0, 0, 1, 0, 0 }, // level 2 simple wave
{ 10, 3, 20, 0, 5, 2, 0, 2, 0, 0 }, // level 3 complex wave
{ 12, 0, 30, 1, 10, 0, 3, 3, 1, 1 }, // level 4 RAMPART
{ 12, 0, 0, 0, 4, 1, 0, 2, 2, 1 }, // level 5 SENTINEL
{ 14, 0, 0, 0, 5, 1, 0, 2, 3, 1 }, // level 6 PRISM
{ 14, 0, 0, 0, 7, 1, 1, 3, 1, 2 }, // level 7 RAMPART difficult
{ 16, 0, 0, 1, 9, 1, 1, 3, 2, 2 }, // level 8 SENTINEL difficult
{ 16, 5, 15, 3, 11, 3, 2, 3, 3, 2 }, // level 9 ALL OUT
Round-robin multiplayer
The family names are in there! The game stores up to seven player names. Swapping them for your actual family takes five minutes and one USB cable. The display announces whose turn it is between rounds, which creates a surprisingly effective amount of anticipation in children aged five to fifteen.
Each player takes their turn on each level in a fixed (randomly determined) order. Get eliminated and you watch from the sidelines: your score stays, your pride does not. Up to seven players, last one standing wins. Tiebreaker: most levels completed.
High scores are stored per level per player in EEPROM. After elimination, the LED strip shows your score in white against the high score: white for what you achieved, red for the gap to the record, green if you broke it.
The Hardware
- Arduino Mega 2560
- WS2815 LED strip, 12 V DC, 120 LEDs, 2 m (IP67, therefore survivable by small children)
- TM1637 six-digit display
- Three coloured push buttons with built-in LEDs (red, green, blue)
- One black push button (confirm / long-press restart)
Every connection in the build uses screw terminals so no soldering is required to swap a component. The strip burns out? Unscrew two wires, screw in a new one. A button fails after three years of enthusiastic seven-year-old use? Same story. Full right to repair, by design, with a screwdriver.
The strip runs at 12 V for stable colour at reasonable brightness without the voltage-drop shimmer you get at 5 V. The Arduino handles everything: game logic, LED rendering, display, input debouncing, EEPROM storage of high scores and player preferences. No co-processor, no co-pilot, no cloud.
Why Build This?
Because a 2-metre LED strip, some buttons and a microcontroller make a genuinely good family game and one that scales from a toddler's first colour-matching to a teenager's reflex test to a parent trying to prove they still have it. Because it makes no noise. Because it requires no subscription. Because when someone in your family becomes the reigning Prism champion, they should know about it.
The wormhole is open. The invaders are coming. The only question is who's up first.
Jeroen Brinkman
