1How to make MirrorBallBot
This robot has been designed to be open-source, that makes the thinking process a bit more outside-in
This also means I wrote a quite extensive document (How_to_make_MirrorBallBot.pdf), covering several aspects of the robot.
The final doument is about 150 pages long, organized in about 30 chapters and divided in into 4 main sections:
- Section 1: Introduction.
- Section 2: Make the robot.
- Section 3: Use the robot.
- Section 4: Useful (or interesting) info.
- Introduction:
- Overview
- Key innovations
- Robot architecture
- Blocks diagram
- Safety and expectations management
- Make the robot:
- BOM
- Make the MirrorBallBot PCB
- Make the wood base
- Setup the Raspberry Pi 4B+ and the RP2040-Zero
- First tests
- Assemble the robot
- Use the robot:
- GUI
- Info (my preferred part 😊, yet not strictly needed to build the robot):
- Inspiration
- Design process
- Main innovations and main characteristics
- Custom I2C protocol
- PID balance Controller
- Configuartion parameters
- Troubleshooting
- Q&A.
The document can be downloaded from: link to How_to_make_MirrorBallBot.pdf
Andrea Favero
