Absolute LINUX TAB
Made a Raspberry Pi CM5-based tablet that runs pretty much everything we throw at it.
Greetings everyone, and welcome back. Here's something awesome: meet the ABSOLUTE LINUX TABLET, my DIY tablet built completely from scratch. This is a DIY tablet powered by a Raspberry Pi Compute Module 5, paired with a Waveshare 10-inch DSI touch display and an onboard lithium battery, which provides up to 5 hours of continuous usage.
The goal of this project was to create a portable Linux tablet for an upcoming solar project, where I needed a device that I could easily carry from one site to another while working outdoors. A laptop could have been used instead, but I wanted something more portable and convenient to work with. Raspberry Pi OS is perfect for this task, which is why I decided to build a tablet around the CM5 and a touch display.
This Device is a fusion between a touch computer and a tablet. I have used a 4GB variant of the CM5, and for improved performance, I installed the operating system on an NVMe SSD, making the system super fast.
To enhance Wi-Fi and Bluetooth connectivity, I also added an external antenna to the device.
I designed the enclosure in Fusion 360 and printed the parts on my 3D printer in two colours to get a duotone aesthetic.
This article covers the complete build process of the tablet, so let's get started with the build.
IDEA
The whole idea came from the fact that I needed a Linux system—a portable Linux system that would help me with a solar monitoring project I'm working on. I had already been using a Raspberry Pi 4 in that project and needed a device that would allow me to SSH into the setup and monitor the solar cells on the go.
A laptop could have been used for this purpose, but I wanted something more portable, like a tablet that runs Linux. I did a quick Google search and found very few Linux tablets available, so I decided to build one myself since the concept was quite simple.
The project only needed three main components: a small computer, a display, and a battery source. For the computer, I selected the Raspberry Pi Compute Module 5 along with its full evaluation board. For the display, I used a Waveshare 10-inch DSI touchscreen that I already had, which turned out to be perfect for this project. Finally, for power, I repurposed a MagSafe power bank by completely stripping it down and using its battery and charging circuitry inside the tablet.
HARDWARE- WAVSHARE 10.1 INCH DSI SCREEN
For the main display, I wanted something huge, not the average 7-inch size, but something larger.
Connectivity was also an important factor, as I wanted a DSI interface instead of HDMI.
So, I selected Waveshare's 10.1-DSI-TOUCH-A display for this project. It is a portrait touchscreen LCD display with ten-point capacitive touch control. The display uses an IPS panel with a hardware resolution of 800×1280, which is perfect for our tablet application.
The LCD pairs with the Raspberry Pi through the DSI interface and supports a refresh rate of up to 60 Hz, which is more than enough for this application.
The kit comes with two FFC cables for pairing the display with a Raspberry Pi 5 or CM5, one FFC cable for pairing with a Raspberry Pi 4, a power cable, and a couple of PCB standoffs.
You can check out more about this display from its wiki page.
https://www.waveshare.com/10.1-dsi-touch-a.htm?&aff_id=Arnov
http://www.waveshare.com/wiki/10.1-DSI-TOUCH-A
WAVESHARE SERVICE
Special thanks to Waveshare for providing the hardware used in this project. The 10.1 Inch DSI screen and supporting accessories were supplied as review units for testing and evaluation.
Waveshare is a leading global provider of electronic components, modules, and development tools used across robotics, IoT, automation, education, and many other fields. With a strong focus on quality, reliability, and continuous innovation, Waveshare has earned the trust of engineers, designers, hobbyists, and makers worldwide.
Their extensive product lineup, from displays and HATs to expansion boards and embedded modules, makes them a go-to choice for both professional builds and DIY projects.
RASPBERRY PI CM5
The brain of our project is the Raspberry Pi CM5, which is a more industrial-oriented version of the usual Raspberry Pi 5 in a module form factor. It uses the same Broadcom BCM2712 quad-core 64-bit Arm Cortex-A76 (Armv8)...
JPEG Image - 325.34 kB - 06/07/2026 at 09:47
Preview
BASE.stl
Standard Tesselated Geometry - 342.86 kB - 06/07/2026 at 09:47
Download
SW.stl
Standard Tesselated Geometry - 144.91 kB - 06/07/2026 at 09:47
Download
FRAME.stl
Standard Tesselated Geometry - 105.94 kB - 06/07/2026 at 09:47
Download
  • 1
    DISPLAY & CM5 ASSEMBLY
    • We begin the display and CM5 assembly process by positioning the expansion board over the back of the display.
    • We align the mounting holes of the display with the Raspberry Pi board and then use the provided four M2.5 bolts to secure both of them together.
    • Next, we connect the power wire harness. One side is connected to the JST connector on the display, while the other end goes to the Raspberry Pi's GPIO header. We connected 5V to 5V and GND to GND. Basically, the display will be powered directly from the GPIO header of the Raspberry Pi.
    • Next, the FPC cable is added. We first connect it to Port 1 on the Raspberry Pi expansion board and then connect the second end to the display's FPC connector.
  • 2
    CONFIG FILE EDIT
    We plugged in the power and were hoping this would be a plug-and-play job, but things are never that simple, and the display didn't work straight away.
    We needed to connect an external monitor to our CM5, open a terminal, and then edit the config.txt file.
    We added the following line at the bottom of the file.
    dtoverlay=vc4-kms-v3d#DSI1 Usedtoverlay=vc4-kms-dsi-waveshare-panel-v2,10_1_inch_a#DSI0 Use# dtoverlay=vc4-kms-dsi-waveshare-panel-v2,10_1_inch_a,dsi0
    On the wiki page for this display, to Waveshare's credit, they did include a custom pre-flashed Raspberry Pi OS Trixie image. If we use that image and flash our Raspberry Pi with it, the display boots up without requiring any manual edits to the configuration files.
  • 3
    FRAME ASSEMBLY
    Frame assembly begins with the placement of the display and Raspberry Pi assembly into their designated position.
    Here, we didn't need to use any adhesive, as the display will be locked in place once the back part is added.
View all 11 instructions
