The Core Concept: Network-to-DAC Streaming
Both projects share the same foundational DNA: instead of relying on specialized USB SDR controllers, they utilize standard Gigabit Ethernet (or USB Ethernet gadget mode) to receive baseband or RF I/Q data streams directly from a host PC. This data is then routed via Direct Memory Access (DMA) to high-speed parallel GPIO buses, which clock the data into an external Digital-to-Analog Converter (DAC).
Platform 1: smiSDR (Raspberry Pi Ecosystem)
smiSDR project is built around the Raspberry Pi, utilizing its Secondary Memory Interface (SMI).
- Hardware Compatibility: The project supports DACs ranging from simple 8-to-10-bit R2R ladders to common 12-to-14-bit parallel IC-DACs. The bus width can be configured on-the-fly via a control port (Port 5000).
- Performance: Because the SMI interface is entirely DMA-driven, the Raspberry Pi's CPU remains practically idle, even when pushing high RF data rates.
- The Ideal Board: The Raspberry Pi 4 is the flagship for this project due to its native Gigabit Ethernet. While older boards (like the Pi 3B or Zero 2) can be used via USB Ethernet Gadget mode, they offer reduced performance. Notably, the newer Raspberry Pi 5 lacks the SMI hardware block entirely (favoring the PIO interface), making it incompatible with this specific architecture.
Platform 2: parlioSDR (ESP32-P4 Ecosystem)
For an even more cost-sensitive approach, the parlioSDR project leverages the Espressif ESP32-P4 microcontroller. Espressif's newer microcontrollers feature the Parallel IO Controller (PARLIO), which serves a similar function to the Raspberry Pi's S
- Networking: The ESP32-P4 receives the data stream via Ethernet, acting as a drop-in network target just like the smiSDR.
- Current Limitations & Roadmaps: While newer Espressif chips like S31 are theoretically Gigabit-capable, current ESP32-P4 dev boards present a bandwidth bottleneck over Ethernet. To overcome this, the architecture is currently being evaluated for USB 2.0 streaming, which provides the necessary throughput for wider signal bandwidths.
The Software Protocol
Both platforms utilize a simple two-port system that mimics network-attached instruments:
- Port 1234 (Data): Transmit the raw TCP stream of baseband or RF data from the host PC.
- Port 5000 (Control): Receives raw text commands to configure hardware parameters on-the-fly. For example, sending
echo -n "rate 5" | nc -w 1 <IP> 5000instantly shifts the hardware clock to 5 MSPS.
Future Horizons: Towards a "Budget Red Pitaya"
While the current implementation focuses on replacing the FL2000 as an SDR transmitter, the underlying DMA-to-Parallel architecture is inherently bidirectional.
The next logical evolution of this DNA is reversing the data direction to integrate high-speed ADCs, creating a fully functional SDR receiver. Furthermore, by designing custom HATs or shields that feature a low-cost FPGA between the parallel bus and the RF front-end, users could implement hardware-level Digital Down Conversion (DDC) and Digital Up Conversion (DUC).
This would effectively turn a standard Raspberry Pi 4 or an ESP32-P4 into an architecture mirroring the highly respected Red Pitaya, but at a mere fraction of the cost, lowering the barrier to entry for educational institutions, makers, and amateur radio operators.
*** Check out the repositories on GitHub to explore the code, build your own HATs, and join the development.
thomaswust79
David Michaeli
Ashwin K Whitchurch
Christopher.Scott
