We had some issue with the design so we need to think about something new to keep the project going.
We need to leave the 3D model behind because the printer won't be able to print what we need....
We're still working on the finlal code to use all the components together at the same time. We only need to add the WiFi connection and create an UDP server to transmit all the datas from the arduino to our computer.
