The project is compatible with the 8-bit Workbench™ extension bus and can connect to other projects of mine:
- Super Breadboard 2; enjoy short circuit protection. Have both +3.3V and +5V at hand. Clearly separates data input and output of your prototype. Can work standalone as well.
- Terrific Timer; a versatile clock board that provides an adjustable astable clock (0.7 - 480 Hz) and a monostable pulse (110 ms). Lets you insert custom 555-timer parts.
- Byte Adder Subtractor. An 8-bit full adder. Explore bit-level addition and subtraction.
- Binary Keyboard; adds a retro 8-bit toggling experience to your experiments.
- Hex Keyboard; turn-in a hexadecimal code (0-F) for the high- and the low-nibble. The output, a full byte (8-bits), can then be used with attached experiments. Supports a Logic Probe as well.
These are all available as kits.
More information is on my website.
Dave's Dev Lab
TEC.IST
