This project is a custom ultra-high-density EEG device, NOT a standard medical or consumer EEG headset.
  • Device Name: FreeEEG16-alpha2
  • Form Factor: 26mm diameter circular PCB.
  • Electrode Array: 18 pogo pins tightly packed within the 26mm area.
    • 16 Active Positive Channels (+)
    • 1 Common Reference (-)
    • 1 Ground (GND)
  • Placement: Works entirely locally, primarily targeted at the Pz (parietal) placement.
  • Key Capability: NO distant electrodes are required. Reference and Ground are located in the same 26mm cluster.
  • Performance: When placed on Pz, the system provides a high-fidelity real-time loop. Users can observe immediate bio-reactive changes in procedural shaders, minimizing the cognitive load required to establish stable neurofeedback.
firmware Sender_BLE5_Data_2M_16_alpha_2_1_esp32_c6:
https://github.com/neuroidss/FreeEEG16-alpha2/tree/main/Sender_BLE5_Data_2M_16_alpha_2_1_esp32_c6
gamepad firmware Sender_BLE5_Data_2M_16_alpha_2_1_esp32_s3_gamepad_ble_usb:
https://github.com/neuroidss/FreeEEG16-alpha2/tree/main/Sender_BLE5_Data_2M_16_alpha_2_1_esp32_s3_gamepad_ble_usb
Neuro_Test_Bench:
https://neuroidss.github.io/FreeEEG16-alpha2/Neuro_Test_Bench/Neuro_Test_Bench_PRO_16CH.html
NEURO-CULTIVATION:
https://github.com/neuroidss/NEURO-CULTIVATION
Live Demo:
https://neuroidss.github.io/NEURO-CULTIVATION/
