Image 1: The laser-cut plywood sides of the box, flat before assembly. The interlocking tabs and slots allow the structure to fold and click together without glue. The circular apertures at the top accommodate the flashlight and the lens holder.
Image 2:
The same plywood net seen from the outer side, laminated with the adhesive iridescent paper sheet that will become the outer skin of the assembled box. The paper serves a dual purpose: it holds the structure together and gives the lamp its distinctive visual identity - even before it's switched on.
Image 3: Plywood laser-cut net.
Image 4: Adhesive sticker template.
Image 5: Left: the lens holder — a cylindrical tube (3D-printable) that houses the projection lens and allows the distance between lens and soap film to be adjusted, bringing the projected image into focus. Right: an 800-lumen tactical flashlight with a zoom function — this last feature is not optional. The ability to concentrate the beam onto a small area is what gives the soap film the intensity it needs to produce vivid, saturated colour on the projection surface.
Image 6: The film generation system. Left: the soap film holder — a 50mm diameter, 100mm long plastic tube with a crossing pivot that sticks out of each side of the box. At the top (and at the bottom, not visible in the photo), a gasket is mounted in a deliberately undulating (rather than flat) configuration; this subtle waviness in the film surface adds complexity to the projected image, producing richer and more varied colour patterns. To charge the film, the tube is briefly dipped into the soapy water tank (right) then raised and placed vertically. A fresh soap film forms across the gasket, and the reflection of the flashlight on it is projected outside.
Image 7: The lamp fully assembled, with one side panel opened to reveal the internal layout. The soap film holder sits inside the soapy water tank at the bottom of the box, with the freshly formed film glowing brilliantly under the focused flashlight beam from above. The lens tube (top left aperture) is positioned above the film, ready to project the interference pattern outward. Once the final panel is closed, the box becomes a "lanterna magica" — and the show begins on the wall.
Michele Lorenzi
Steve Dearden
Quinn
Stephen Holdaway
If any hacker is interested in building their own Maelstrom Lamp, I'm considering selling on Tindie the components that are hardest to source - mainly the lens and possibly the flashlight. I'm also thinking of offering a full assembly kit with everything included. Before I set anything up I'd like to gauge interest first, so if either option appeals to you, please drop a reply here - it really helps me decide what to prepare. Let's build this thing!
