I've only just realized I didn't provide enough information about the lens: here are the full specs, measured with a caliper and verified experimentally.
The lens is a biconvex acrylic lens — the classic double-convex shape, thicker at the centre and tapering symmetrically toward the rim. It sits in a plastic mounting frame which fits into the lens holder tube.
Measured specifications:
- Type: biconvex, acrylic
- Optical aperture (lens only): 31mm
- Total diameter including frame: 43mm
- Frame width: 6mm
- Centre thickness: 5.8mm
- Edge thickness: 2mm
- Focal length: 70mm
I sourced my lens from a scientific toy — the manufacturer was kind enough to send me samples, but I'm not in a position to name them here. The good news is that an equivalent lens is easy to find: search for "biconvex lens 30mm 70mm focal length" on AliExpress or similar platforms, or consu
lt optical suppliers such as Thorlabs or Edmund Optics. The exact dimensions don't need to be identical — some experimentation with the tube length will compensate for small differences in focal length.
Michele Lorenzi
