One limitation of the original design was that the projection naturally falls on a horizontal or near-horizontal surface. To cast it onto a vertical wall — a much more practical target for ambient or therapeutic use — I added a convex mirror sourced from a standard bicycle rear-view mirror (the original mounting bracket removed).
The mirror is held by a custom support made from a length of thick iron wire threaded through the sheath of an electrical cable. This gives the arm structural rigidity while remaining malleable enough to be repositioned freely — the mirror can be angled in virtually any direction without tools. The arm slots into a small C-shaped retaining clip fixed near the rim of the lens holder, and rests against the side of the box for stability.
The convex geometry of the mirror serves a dual purpose: it redirects the projection onto a vertical surface, and simultaneously enlarges it slightly — a welcome bonus requiring no additional optics.
The result is a simple, tool-free attachment that significantly expands where and how the lamp can be used.
Michele Lorenzi
