Convex Mirror Attachment — Wall Projection Module
06/24/2026 at 13:54 • 0 comments![]()
One limitation of the original design was that the projection naturally falls on a horizontal or near-horizontal surface. To cast it onto a vertical wall — a much more practical target for ambient or therapeutic use — I added a convex mirror sourced from a standard bicycle rear-view mirror (the original mounting bracket removed).
The mirror is held by a custom support made from a length of thick iron wire threaded through the sheath of an electrical cable. This gives the arm structural rigidity while remaining malleable enough to be repositioned freely — the mirror can be angled in virtually any direction without tools. The arm slots into a small C-shaped retaining clip fixed near the rim of the lens holder, and rests against the side of the box for stability.
The convex geometry of the mirror serves a dual purpose: it redirects the projection onto a vertical surface, and simultaneously enlarges it slightly — a welcome bonus requiring no additional optics.
The result is a simple, tool-free attachment that significantly expands where and how the lamp can be used.
Update: The Lens — Specs and Sourcing
06/17/2026 at 11:16 • 0 commentsI've only just realized I didn't provide enough information about the lens: here are the full specs, measured with a caliper and verified experimentally.
The lens is a biconvex acrylic lens — the classic double-convex shape, thicker at the centre and tapering symmetrically toward the rim. It sits in a plastic mounting frame which fits into the lens holder tube.
Measured specifications:
- Type: biconvex, acrylic
- Optical aperture (lens only): 31mm
- Total diameter including frame: 43mm
- Frame width: 6mm
- Centre thickness: 5.8mm
- Edge thickness: 2mm
- Focal length: 70mm
I sourced my lens from a scientific toy — the manufacturer was kind enough to send me samples, but I'm not in a position to name them here. The good news is that an equivalent lens is easy to find: search for "biconvex lens 30mm 70mm focal length" on AliExpress or similar platforms, or consu
lt optical suppliers such as Thorlabs or Edmund Optics. The exact dimensions don't need to be identical — some experimentation with the tube length will compensate for small differences in focal length.
Michele Lorenzi
