to build this you need:
- an ultimaker original
- 2 carbon tubes 4mm diameter length 166
- 1 standard servo
- 2 micro servos (Reely RE-6609276 ) conrad 2203092
- brass tube diam 2.5 length 11 mm
- 14 m2 bolts (various lengths
- 7 m2 nuts
- 3 m3 bolts 25 mm
- some m2 and m3 washers
- some nylon wire
- some low friction material (teflon foil)
- some iron wire
- hotmelt glue
- 3 printer with PLA filament
- CA glue
MECHANICUS
dekutree64
Norbert Heinz
