https://github.com/MadHatter-Auditor/vortex-anapole-confinement
readme:
Read the PDF file called Base-12 Microcosm.
Contents part 1 Base-12 Microcosm.pdf
Zodiac coil.png Assem1.SLDASM & Assem1.SLDDRW Base-12 Klock system α & ω.png Bifilar Conical Caduceus Coil.jpg Cadecus.SLDDRW & Cadecus.SLDPRT Chessboard Base-12.png Dodecagram.png & Handmal.jpg Hiemona Coil.SLDDRW & Hiemona Coil.SLDPRT Hiemona Coil Measurements radius plus paths.jpg Hiemona Coil Paths.jpg & Hiemona Coil.jpg Hieroglyphica monas.SLDDRW & Hieroglyphica monas.SLDPRT Module-12 2D.SLDASM & Module 12 2D.SLDPRT Module-12 Assembly.SLDASM & Module-12 Assembly.SLDDRW Module-12 Coil main.SLDPRT SOH Tower & SOH fractals collours.jpg SOH antenna fractals.SLDDRW & SOH antenna fractals.SLDPRT SOH antenna p2 base.SLDPRT & SOH antenna.SlDDRW Seal of hermes symbol.SLDDRW & Seal of hermes symbol.SLDPRT Seal of Hermes measurements.jpg Sri Yantra measurements radius plus paths.jpg Sri Yantra measurements radius.jpg Sri Yantra Coil half Radius drawing.SLDDRW & Sri yantra coil half.SLDPRT Sri yantra testdrawing.SLDDRW & Sri Yantra.SLDDRW Alchemical alpha omega torus basis & alchemical alpha omega torus graph Nordic runes on zodiac.jpg
contents part 2 Material Roadmap.pdf
RC simple coil.SLDPRT & RC simple coil.jpg RC thin wire raster drawing.SLDDRW & RC thin wire raster.png RC split ring resonator drawing.SLDDRW & RC split ring resonator Drawing.png
contents part 3 Asterion Perun Machine (APM).pdf
QEG P1 PIN IN ROTOR.SLDPRT &QEG PIN IN STATOR.SLDPRT QEG P1 PVC PART.SLDPRT & QEC P1 MICA PLATE.SLDPRT QEG P1 STATOR & ROTOR.SLDASM QEG P2 BACKPLATE.SLDPRT & QEG P2 FRONTPLATE.SLDPRT QEG P2 BOTTOMPLATE.SLDPRT & QEG P2 BOLT.SLDPRT QEG P2 ROTOR PIN P1.SLDPRT & QEG P2 ROTOR PIN P2.SLDPRT QEG ROTOR PARTS ASSEMBLY 1.png & QEG ROTOR PARTS ASSEMBLY 2.png QEG ROTOR PARTS DRAWING.SLDPRT & QEG ROTOR PARTS DRAWING.png QEG ROTOR PARTS REWORKED.SLDASM & QEG STATOR PARTS DRAWING.SLDDRW QEG STATOR PARTS DRAWING.png & QEG STATOR PARTS REWORKED.SLDASM
contents part 4 Soyga.pdf
Greek Soyga Matrix colloured.xlsx Greek Soyga Matrix.xlsx
Appendix The Meta-Academic Response Framework (MARF) The-Book-Of-Signs-Vol-i_text.pdf
<<note from author, banned on reddit so please share>> <<note from author, added RC simple coil. 1-6-26>> <<note from author, added RC split ring resonator. 1-6-26>> <<note from author, added RC thin wire raster drawing. 2-6-26>> <<note from author, added topics. 2-6-26>> <<note from author, added alchemic correlation in resistance trough RC.pdf 2-6-26>> <<note from author, added multiple drawings and cleaned up some mess see commits 2-6-26>> <<note from author, did apeal two times but still shadowbanned on reddit, no responce about it either from mods, still no idea what happend>> <<note from author, SOH fractals did improve but they are still a bitt faulty, one should not expect a perfect SLDPRT.. on the macro scale it looks fine but it is incorrect on the micro scale. need to rework or redesign that later but improvements or fixes are welcome. 2-6-26>> <<note from author, added the book of signs, this is all i could find because most if it is lost media, i cannot scan in my personal collection at this moment so this must suffice for you all. 3-6-26>> <<note from author, added a new section in the material roadmap about the Leibniz' Binary System and Shao Yong's "Yijing 4-6-26>> <<note from author, added a new section in the material roadmap called: The Wu Xing binary system. 4-6-26>> <<note from author, added The Meta-Academic Response Framework (MARF). 4-6-26>> <<note from author, updated the Material roadmap, defined using π. 12-6-26>> <<note from author, reworked README to provide a more clear overvieuw. 4-6-26>> <<note from author, added The Asterion Perun Machine and reworked readme 7-6-26>> <<note from author, deleted my reddit profile because of the ban and no responce even while being polite, i do not waste my time with them so i deleted my info since...
madhatter
Jan Mrázek
Cory Collins
