Making the forearm launcher Part 1
A project log for Iron Man Armor Mark 42
Using tech to make Iron man's armor.
walkerdevWalkerDev 03/23/2017 at 21:510 Comments
So I found these files online and decided to print them out. I am currently having them be printed out by a friend. To scale, I first needed to find the scale, then had to add space for electronics, padding, kydex, and other things. I am about to start cutting some steel sheets for a forearm launcher. I am also programming the motherboard for RFID tags to control everything, and trying to Bluetooth sensors to Jarvis. I continue to ask myself how to get the gauntlet to have bio-metric sensors and open/close.
Here are some pictures of the 3d models wanted.
A picture of the parts wanted to be 3d printed.
**All credit given to Abb eliten for files**
(files) http://www.therpf.com/f78/my-mk-42-build-new-stl-files-upper-arm-section-166141/?highlight=mark+42+forearm
A want of the frame.
**All credit given to maker from CGtrader, I do not own any of these files **
(files)http://stlfinder.com/model/iron-man-mark-iii-forearm-frame-right-side-3d-print-model/3313851
After this, I will start on developing the rocket systems and putting the 3d files together. I will start to also work on laser weaponry (forearm sentry, repulsor, and rocket guidance).
