Exo suit (quick update)
A project log for Iron Man Armor Mark 42
Using tech to make Iron man's armor.
walkerdevWalkerDev 04/23/2017 at 11:590 Comments
Remember this from the last blog? If you didn't read the last blog, I suggest you do. If you did, keep reading. As I said earlier, this is a really good base for the suit, because it is flat, easily adaptable, and it is needed. To start everything off, let's start out with the gauntlet (forearm and bicep). I'm thinking of using pneumatic cylinders, and using some type of weight help in the bicep to shoulder piece. I'm trying to get a hold of this guy, so that I can talk to him about 3d files. I would then be able to get it into a format-able template to make it by hand, or just order it to be 3d printed, but I don't think it would be easy to scale for someone 6.2 (yeah im tall ). I may leave air vaults for each limb, instead of having one. This may take up space, but each limb will have extreme strength. Buying metal now.
Just a quick update.
From me
Thekidtonystark
