A super quick update (funds + flying)
A project log for Iron Man Armor Mark 42
Using tech to make Iron man's armor.
walkerdevWalkerDev 05/03/2017 at 19:030 Comments
https://www.gofundme.com/thekidtonystark
This helps me get the money for the suit.
In other news, I am using Ion propulsion for the feet. The only problem is that at 120 volts, the ion propulsor will only push a piece of paper. What I could really use is that arc reactor. Here's a quick thought. If 120 volts push paper and to push paper I need let's say 6 grams since 5 grams is the weight of average paper. If 1 gram is 453 grams and the paper is 204117 grams, let's do the math.
Now for the energy needed:
Now 54000 volts is a lot. A LOT. I will experiment with an energy source for now, and when finished, will show pics. I also plan on releasing some info on the rocket launcher later. I also will show how I am (attempt) making the muon beam and the generator
Well until later
-Thekidtonystark
