Update (Gauntlets, Jarvis and future plans)
A project log for Iron Man Armor Mark 42
Using tech to make Iron man's armor.
walkerdevWalkerDev 12/13/2017 at 22:180 Comments
So the gauntlet is getting closer to being finished by the second and after quite a while, there's progress coming fast. I've been working on the gauntlet and there are currently three versions made. There's the gauntlet from a year ago, a now recycled gauntlet and this bad boy:
In eh picture quality, there is currently both servos for the rocket launcher opening/closing system, two arduino pro minis (one for rocket launcher, one for gauntlet opening/closing system), a servo tester to test the rocket launcher hold and an opening to mark the sides without hinges. Mini pneumatic cylinders will be added to (hold) the gauntlet and as a cheap way to fix the gauntlet if I grow. There are 6 blue LEDS, 4 of which turn on with the gauntlet opened and two with the rocket launcher opening. Some things to be included once the basic neccesities are there is
- Tungsten to protect metal from melting ( tungsten can withstand about 6,192°F or 3,422°C ).
- Aerogel (maybe but it's kind of expensive) for heat dispertion
-Enviornmental control
-Penny-Sized nanobots for part replacement
and all other typed of stuff
The gauntlet is currently being given rfid tags, wire organization and other fixes.
Then there's Jarvis. @Chati Aro Has been a huge help with Jarvis. Here's some functions so far:
FM = Feature Matching (Matches the features of a given image with a base image and displays the result)
LD = Letter Detection
MD = Motion Detection (Detects any sort of motion infront of the camera
PD = Pedestrian Detection (Can detect any person walking on streets.. Used an image from GTA as an output example)
SD = Shape Detection
Without @Chati Aro, this would not be possible.
While videos are in production, i'm adding in some plans for circuits. Some people may remember this
www.instructables.com/id/Animatronic-Iron-Man-Mk-III-suit/
Well i'm taking the basic ideas of it and am trying to rig it up. Until I start putting in the advanced stuff, that's all for now.
From a random guy
-thekidtonystark
