Hackaday.io Hackaday.io
Sign up Log in
Framework 13 Touchpad to USB bridge
Want a Framework 13 touchpad as a USB touchpad? I did it that
miclmicl
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
0
2
1
Team (1)
  • miclmicl
Join this project's team
  • Famework 13 Touchpad Bridge (repository)
completed project
hardware
FRamework touchpad rp2350
This project was created on 06/23/2026 and last updated 18 days ago.
Description
Turn a Framework 13 touchpad module into a USB touchpad with a simple adapter board. The project is completely open source.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
A breadboard friendly, Arduino-compatible(ish) ATmega328 development board for prototyping USB devices via V-USB ..or not
Project Owner Contributor
RUDY
sven-gregoriSven Gregori
Translate USB mouse/trackball to USB joystick compatible with Xbox Adaptive Controller
USB Mouse or Trackball to XAC Joystick
touchgadgettouchgadget
Hackaday Prize 2019
An USB super speed Type C to Type A adapter which can extract the USB PD signal of the Type C port and use it e.g. for charging.
USB 3.1 Type C to Type A Adapter with PD
jakob-faltisekJakob Faltisek
Mini devboard for Atmel's SAMD11 ARM Cortex M0+ Microcontroller with native USB
samDEV_11
alexAlex
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Framework 13 Touchpad to USB bridge", please tell us the reason.
Send message
Remove Member
