Tipflow Arcade - Pocket-Sized 8-Bit Mini Arcade Cabinet
1. Summary
This is a pocket-sized, fully functional mini arcade cabinet built on the open-source Arduboy ecosystem.
First of all, a huge thank you to the Arduboy community for their rich open-source resources, which provided a clear design direction for my hardware development. The absolute highlight of this project is its 3D-printed interlocking mini-arcade styling. By transforming the traditionally flat, handheld Arduboy form factor into a 3D tabletop structure, the design brings out a much more playful, unique, and mechanical aesthetic.
2. Design Philosophy
2.1 Bringing Warmth to Desktop Geeks
We didn't want to make just another cold, purely functional electronic gadget. As the core philosophy of Tipflow Design, the Tipflow Arcade aims to deliver emotional value and retro companionship to your workspace. Its classic pixel-art arcade aesthetic pairs flawlessly with the Arduboy gaming style, serving as a healing and highly refined desktop ornament even when sitting idle.
2.2 Engineering Challenges
The biggest challenges of this project lay in the grueling refinement of minor engineering details. Although my very first PCB prototype managed to boot up and run after quite a bit of tinkering, I wanted to eliminate any "voodoo" hardware bugs, improve soldering efficiency, and ensure seamless assembly. To achieve this, I went through 6 full iterations of PCB design, hand-soldered over a dozen test boards, and modified the mechanical structure 3 to 4 times to optimize for FDM 3D printing and painless assembly. Every single tweak was a pursuit of absolute stability within a micro-sized footprint.
3. Hardware Architecture & Specifications
The hardware design follows the principles of high reliability, extreme compactness, and deep optimization for FDM 3D printing constraints.
| Component | Specification | Description |
| MCU | ATMEGA32U4-MU | Fully compatible with the Arduboy development environment and its vast community ecosystem. |
| Display | 1.3-inch SSD1306 OLED | High-contrast 128x64 resolution, delivering crisp and authentic 8-bit retro visuals. |
| Power System | 500 mAh Li-Po Battery | Features integrated charging and safety protection circuits for true portable, handheld gaming. |
| Controls | Tactile Micro-switches / Micro Joystick | Delivers that crisp, clicky, and satisfying authentic arcade tactile feedback. |
| Audio Output | Passive Buzzer | Classic 8-bit buzzer that perfectly reproduces nostalgic Chiptune game sound effects. |
4. Mechanical Design & 3D Printing Optimization
4.1 Printability & Support-Free Geometry
As an industrial designer, printability was a top priority during the modeling process. The entire enclosure is highly optimized for consumer-grade FDM 3D printers:
- Overhang & Bridge Control: Through meticulously calculated angled geometries, the main chassis can be printed with virtually zero support structures, drastically cutting down post-processing and sanding time.
- Aesthetic Texture Protection: The print orientation of each part was carefully planned to hide FDM layer lines on non-visible surfaces after assembly, giving the final enclosure a sleek look that approaches industrial injection-molding quality.
4.2 Ergonomics in Miniature
Despite its palm-sized micro form factor, the spacing and layout of the miniature joystick and action buttons underwent strict ergonomic evaluation. This ensures your fingers remain comfortable and cramp-free, even during intense, quick gaming sessions.
5. Firmware & Software Ecosystem
The Tipflow Arcade runs entirely on the rock-solid, mature open-source Arduboy firmware ecosystem.
- Game Compatibility: 100% compatible with hundreds of brilliant open-source 8-bit games developed and submitted by the global community over the years.
- Flashing & Updates: Zero complex configurations required. Users can effortlessly swap games via the onboard USB port using the Arduino IDE or community-driven web uploaders.
LiuHang
Stephen Arsenault
MMVS-DEV
Iqra Rehman
CtrlEnergy
