Add Bumper/Charge Pickup to Base
A project log for Blinky, the Companion Robot
Blinky, a robot, lives with you, feeds itself and will--when asked--report that you have been seen moving around.
mike-rigsbyMike Rigsby 03/28/2017 at 18:560 Comments
Print the bumper/charge rod piece.
Drill a hole in the base to match the hole in the bumper piece (for future wire routing).
Fasten the bumper and the base together with machine screws.
Obtain (2) 1/4 inch by 2 1/2 inch bolts.
These thread into the bumper piece (they will be the charging rods for Blinky).
