Patternflow is an open-source LED synthesizer. Turn four knobs with your fingertips and shape a living, creative-coding pattern on a 128×64 LED matrix in real time. It's a contemporary reinterpretation of Nam June Paik's 1960s piece Participation TV — instead of watching the art, you make it.
The design stays minimal on purpose. It runs off a standard USB power bank, so there's nothing tethering it to a wall — pick it up and take it outside, to a jam session, wherever.
Build it your way
There's more than one path in. Full guides exist for the 3D-printed enclosure with the custom PCB, a laser-cut enclosure version is in progress, and if you don't want to touch a PCB at all, there's a breadboard-and-jumper-wires guide that skips it entirely.
Try it before you build it
The browser-based Pattern Live Simulator runs the same four knobs the physical device has. Find something you like, and if you've got hardware on hand, flash it straight from the browser over Web Serial — no IDE, no drivers.
The globe
Share what you build in the Discord and a point gets added to a live globe on the site, one dot per creator, wherever they are. The goal isn't to sell a device. It's to cover that globe until there's no dark space left.
Why open source
This started as a single post on r/arduino — 150K views, 3,700 upvotes, and far more people asking how to build one than how to buy one. Every part of it is open: schematics, firmware, 3D models, the pattern editor, the build guides themselves.
- Build guide, schematics, firmware, 3D models: github.com/engmung/PatternFlow
- Web simulator, Live Editor, globe, build journal: patternflow.work
- Discord: discord.gg/d2VN2tj2C
- Instagram: instagram.com/patternflow.work
- Crowd Supply pre-launch: crowdsupply.com/engmung/patternflow
Seunghun LEE
joey castillo
Moritz Walter
Andrei Speridião
c.Invent
