Philips MC6400 Vector Graphics
Real-time 3-D wireframe vector graphics — a rotating cube, torus, and sphere — drawn on an analog X-Y oscilloscope, computed live in INS8070 machine code on a 1984 Philips MC6400 "MasterLab" CPU trainer.
The MasterLab has a 1 MHz National INS8070 (SC/MP III) CPU and 1 KB of RAM. With a small home-made R-2R DAC on its expansion bus — plus one tiny analog trick (an RC slew-limit, see below) — it drives a scope in X-Y mode and tumbles solid wireframe solids in real time, all in well under a kilobyte of code.
Programs are loaded onto the machine with PicoRAM Ultimate — a Raspberry Pi Pico-based (S)RAM/ROM emulator and SD-card interface for vintage single-board computers. As far as I know this is the first expansion-port peripheral ever built for the MasterLab.
MC6400 + R-2R DAC driving a Tektronix 2335 analog scope showing a vector cube
The full rig: a Philips MC6400 with the home-made R-2R DAC on its expansion bus (right), driving a Tektronix 2335 analog oscilloscope in X-Y mode (left) — drawing a solid, rotating 3-D cube. Everything runs live in under 1 KB.
How this was made. Every line of code, all of the tooling (the INS8070 assembler, cycle-accurate simulator, and oscilloscope renderer), all of the assembly programs, and the R-2R DAC hardware design in this repository were written by Claude (Anthropic, Opus 4.8) working under my direction, from the assembler all the way to the rotating sphere and the on-hardware bring-up. I (Michael Wessel) supplied the hardware, the MC6400 manual and INS8070 references, the goals and design choices, and — crucially for this project — the testing and feedback on the real scope at every step.
Status: built and running on real hardware ✅
The R-2R DAC is built and verified on a real Philips MC6400, driving a Tektronix 2335 analog oscilloscope. It draws solid, continuously-rotating 3-D vector wireframes — cube, torus, and sphere — live, in under 1 KB of INS8070 machine code each. The photos below are the real scope, not renders.
vector cube on the 2335 vector torus on the 2335 vector sphere on the 2335
Cube, torus, and sphere — solid analog vectors on a Tektronix 2335, computed and streamed live by the MC6400.
The one surprise: you need an RC slew-limit
Getting from "it runs" to "you can see vectors" turned out to be the whole story of the hardware bring-up, and it's worth documenting because it is not obvious and it bites everyone the first time.
The problem — dots, not lines. The DAC is a step DAC. Writing a new (X, Y) makes the op-amp jump to the new voltage in a few microseconds; the CPU then parks there ~100–200 µs while it computes the next point. So the beam spends almost all of its time sitting on the vertices (bright dots) and only microseconds sliding between them (near-invisible). Out of the box you get a recognisable but dotted figure — never solid lines — no matter how you set up the scope. Cranking the intensity just blooms the dots.
Why the scope's own "vectors" don't save you. An analog scope has no "vector mode" — its beam is always drawing wherever X,Y are; the issue is purely that it flies between points too fast to light them. A digital storage scope does have a "Display Vectors" option, but in X-Y it connects consecutive samples in acquisition order, sampled asynchronously to the DAC with a bandwidth-limited horizontal channel — so DSOs are simply poor X-Y vector monitors (see Scopes). We chased this for a while before realising it's fundamental.
The fix — draw the lines in hardware. Real vector displays (Vectrex, Asteroids, Tektronix storage tubes) move the beam at a constant velocity between endpoints so the whole line lights evenly. You can approximate that on this DAC with a two-part, reversible add-on: slew-limit each output with an RC low-pass, so every DAC step becomes a ramp. The beam then sweeps continuously along each edge — the dots...
