What it is
NASSCAD 4.7.0 — MEDUSA is a parametric 3D CAD application with a browser interface and local model processing. The browser handles the viewport, modeling tools and file exchange; MEDUSA, a native engine running on your computer, handles boolean operations.
The current version uses an HTML entry point with bundled JavaScript and WebAssembly files, served over local HTTP. Earlier single-file releases, including the standalone 4.2.7 application, remain available.
NASSCAD in action
See the project gallery for STEP assembly screenshots from nasscad.com.
Cruise ship assembly — 2,813 solids. Model: Modern Cruise Ship Evita by Christian Spreafico.
Scania 8x4 — 1,449 solids. Model: Scania R620 V8 8x4 by Ivo Jardim.
Scania V8 XT Turbo — 1,295 solids. Model by Ivo Jardim.
Architectural model — 161 solids. Model: Rocky House by Christian Spreafico.
These third-party models remain the property of their authors. They are published on the GrabCAD Community Library and redistributed as STEP test data by STEP Tools, Inc. The illustrations show their import into NASSCAD; model files are not included with the application.
Why it exists
The goal is to keep CAD accessible and models under the user's control. NASSCAD processes models on your machine and can work without an internet connection once its components are downloaded. No account or cloud backend is required.
Core capabilities
- 18 watertight parametric primitives and generators for screws, nuts, gears, pipes and text.
- 2D sketching and NassScript, the built-in JavaScript console.
- Real B-Rep fillets and chamfers using OpenCASCADE in WebAssembly.
- STEP AP203/AP214/AP242 import and STEP AP242 export, with colors and assembly support.
- IFC building-model import and IFC4 export.
- Non-destructive boolean construction trees using MEDUSA.
- Mesh exchange: STL, OBJ, 3MF, GLB and PLY.
- Printer build-volume visualization, measurement tools and persistent undo/redo.
MEDUSA: native booleans, local processing
MEDUSA uses Manifold in native C++ with oneTBB for multithreaded boolean operations. It communicates with the browser over local HTTP.
MEDUSA is required for Union, Subtraction and Intersection. Viewing, primitives, fillets, chamfers and file import/export work without it. The current version does not fall back to browser-based Manifold for booleans.
Build bundles are available for Windows, native Ubuntu and Ubuntu/WSL, with build and deployment instructions included. See the GitHub setup guide.
Real-world stress test — earlier browser-only version
The original project demonstrated import of the Voron Stealthburner CW2 assembly: 198 individually selectable objects, approximately 577k vertices and 192k faces, with a non-manifold sub-mesh flagged. It also reported import tests using NIST STEP reference files. These historical tests describe the earlier browser-only implementation, rather than new MEDUSA validation results.
Model credit: Voron Design — Stealthburner CW2 Assembly, Voron-Stealthburner (GPL-3.0).
Tech stack
Three.js for rendering; OpenCASCADE in WebAssembly for browser-side B-Rep and STEP tools; web-ifc for IFC import; and MEDUSA, using native Manifold and oneTBB, for local boolean operations. Bundled runtime components support offline use without a CDN.
Try it and download
- NASSCAD website
- Main repository and setup instructions
- Downloads and releases
- Earlier standalone 4.2.7 version
For a local checkout, keep the bundled files together and serve the application directory over HTTP, for example with python -m http.server 8080. Open http://localhost:8080/NASSCAD_V4_7_0.htm, then build and start MEDUSA to enable boolean operations.
About the creator
Built solo, nights and weekends, by a self-taught developer and electronics technician — no CS degree, no team, no funding. Everything in NASSCAD was learned by building it. Development follows an AI-assisted workflow: architecture, decisions, and debugging strategy are human-driven; Claude...
Nasser
biemster
Roni Bandini
