SCINTIX P4 is a compact compute module that brings real-time MCU performance into the Raspberry Pi CM4/CM5 carrier ecosystem. It's different from every other compatible module because it features a real-time ESP32-P4 MCU into the same mechanical and electrical footprint. This gives MCU developers the determinism, instant boot, and low power consumption they expect. To our knowledge, this makes SCINTIX P4 the first MCU-based compute module ever released in this form factor.
Plugged into a CM4/CM5 carrier, SCINTIX P4 gives you immediate access to displays, cameras, Ethernet, USB, and all the peripherals the ESP32-P4 exposes, no custom hardware needed. Standalone, it runs powered and programmed over USB Type-C. When it's time to go from prototype to product, the SoM can make the transition as well. Custom carriers can be reduced down to only the components you need broken out, which simplifies your design, streamlines certification, and speeds up time to market.
And because a board is only as good as what you can do with it: we ported DOOM to it and let an AI — Claude Sonnet — play the physical game over an MCP interface. Full story + video in the companion project "Claude Sonnet plays DOOM on SCINTIX P4" https://hackaday.io/project/206493-claude-sonnet-plays-doom-on-scintix-p4
