final project, kind of problem 26/05
06/01/2017 at 08:17 • 0 commentsfinally, the project wasn’t a success but with more components, time and knowledge, it could be feasible. The most important step to keep is, make a solenoid with copper, put a magnet in the middle and create a movement. Create a link between the solenoid and rectifier bridge with Ac and same with DC between rectifier bridge and batterie.We would like to say thank you to the CRI to give us a chance to make a project in English.
rectifer bridge part 2 19/05
06/01/2017 at 08:16 • 0 commentswe found a solution for the magnet, we decided to stick springs on the magnet. No problem with magnetism and it will rebound off the two sides. Today, we’re watching for the rectifier bridge but before doing it, we need to know what current will arrive from the solenoid, we need to check It. We took a multimeter and we watched the current in the solenoid.1.5 mA was measured after few movement. To be large, we decide to take 1A to the rectifier bridge
design moment 28/04
06/01/2017 at 08:15 • 0 commentswe’re finishing the design of the box but we have to make some adjustments as the design was too small because of a problem when we used makercase.com; the batteries and solenoid couldn’t fit in the box. When the box was good, we tried to find a solution for the link because the battery can’t be linked directly to the rectifier bridge. Battery doesn’t like when it’s hot so we want to sold a conductor wire between the spring of battery and rectifier bridge.
problem are arrived 21/04
06/01/2017 at 08:14 • 0 commentsIt was complicate to print the box in 3D because it takes too much time and someone of the CRI proposed to take some wood, to design it on makercase.com. It we will not be as specific as a 3D print but, easier to use it, make it and it’s faster. We designed a box for the solenoid and a box for the battery. For reasons of space, we decide to keep only 2 battery instead of 5. We were looking for a good material but the simplest was the wood. Easy to work with and to cut.
little boxes 07/04
06/01/2017 at 08:13 • 0 commentsA part of the stuff is arriving so we’re trying to install the copper in solenoid. We’re working on a small size to keep it on the arm, but it need to be a bit powerful to have what’s necessary to recharge a cellphone. We’re beginning the design of the box . But technical question is on the table: how to build the box? In first time, we began to design it on Solidworks, it enabled us to have all the good dimensions and we made different trials.
research to the stuff 31/03
06/01/2017 at 08:12 • 0 commentsOur list of the necessary stuff is almost complete; we’re watching for the rectifier bridge if we want to make it or buy it. But our engineering minds said to do it so we’re asking for diodes to make it. In a second time, we’re designing the box for the solenoid and the magnet. The challenge is to have a good spring for the magnet, it will rebound off two sides of the box and it needs to not be magnetic. -
walk machine 24/03
06/01/2017 at 08:11 • 0 commentsafter many concertations, we want to make a prototype that we can put on the arm. But it can be put to another place. The magnet needs to move a lot and if we put it on the arm, it will move like we want when we’re walking (lot of people are moving every day, at least to go to the workplace) . If we’re walking 20 minutes at 5km/h , it’s more than 2000 movements for the magnet in the solenoid.
rectifer bridge 10/03
06/01/2017 at 08:10 • 0 commentsTo make energy, we’re using a magnet that is moving inside a solenoid to make energy, AC will arrive in a rectifier bridge and this one will convert in DC. This is directly going in 5 batteries to keep energy. If we want to recharge the smartphone, it is very easy, just connect the cellphone with the link and wait!
pocket energy is born ! 03/03
06/01/2017 at 08:09 • 0 commentsFirst, we were searching how to recharge a smartphone without plugging it. This choice was made ecause cellphones are everywhere and there are 1.4 billons worldwide and it uses too much energy. Because every day, we are moving, we can maybe find a solution to make energy when we’re walking, with the movement of our body. Pocket energy is created!
brainstorming 24/02
06/01/2017 at 08:08 • 0 commentsafter a brainstorming, too many ideas were said but not a real project. We watched some videos on the internet to find inspiration. We thought about a battery recharged by a crank but it already exists. Interesting day but no real project was found.
