This is a project I've been wanting to finish for a while, a fully customizable cyberdeck I can offer as a DIY tutorial for my youtube page you can build yourself using off-the-shelf components! Based on the ESP32 microcontrollers and programed in arduino.
Features:
-Digital clock with NTP time sync — automatic on WiFi connect
-Speed Test: Measures upload and download speeds via wifi
-SD Card Browser -Notes / Data log: Write and save notes to SD card
-WiFi Scanner — Scan of nearby networks showing SSID
-BLE Scanner — Scans for nearby bluetooth devices
-Serial Terminal — full-duplex UART terminal Games:
-Snake -Game of Life (Conway's cellular automaton)
-Dice Roller (d4, d6, d8, d10, d12, d20 with animated roll)
-Tetris
Tools:
-BT Keyboard: turns the cyberdeck into a Bluetooth keyboard, can control any bluetooth enabled device
-Calculator -Unit Converter: convert between common measurement units
-QR Generator: text or WiFi credentials as a QR code on screen
-Compass: live magnetometer compass with animated analog display
-Radar — WiFi motion detector radar, uses wifi connection to detect nearby movement
-Password Vault: encrypted password storage
Stopwatch
-IR Blaster/Receiver — capture IR remote codes and use the cyberdeck as a universal remote for IR devices (such as televisions)
-Calendar/Agenda
-Altitude Tracker
-Waypoint Navigator — enter latitude and longitude coordinates, compass will point to the destination, no GPS needed
-Environmental/weather status page - uses built in sensors to display local temperature, altitude, air pressure, etc
-customizable color theme editor
- Multiple cyberpunk-themed Screensavers (5 styles)
This is the first prototype, so there may be some slight changes to the final version shown in the tutorial.
The tutorial will go up on www.youtube.com/@graystarinnovations soon! See less
Ian Maday
YUMO.BUILDS
ElectroScope Archive
Dan Julio
Great variety of apps. Just the library to do all those functions is quite useful. Would it be easier to build without the keyboard? And use something like this $19 wireless Bluetooth kbd? https://www.amazon.com/Arteck-Ultra-Slim-Bluetooth-Compatible-Including/dp/B07PFCRWG9/ref=sr_1_5
