1Compile & encrypt the ROM
Compile and encrypt the ROM for the cartridge following the compiling information in this repo.
2Compile the RP2040 firmware
Compile the firmware with your ROM following the guide here.
IMPORTANT: The DSpico has a function to automatically reset if the microSD card isn't inserted when powered on. This behavior can be disabled by commenting this line present on main.cpp:
initSd(); // tryRebootToBootsel(); <-- Comment this pwr_initPowerSaving();
3Fabricate the Flashcart
Grab the files present in GerardGascon/fanzine-ds-hardware and export all the fabrication files from there.
If you are using JLCPCB for the production, they have a guide here + a plugin that easily generates those files for you.ADVISE: If you want to test the software before fabricating the hardware, you can do so by just using an existing DSpico and later on fabricate the flashcart.
Geri
