EasyPWR Deluxe build complete
A project log for EasyPWR
A small, easy to assemble board that makes use of old wall warts.
mcu_nerdmcu_nerd 09/30/2017 at 17:302 Comments
Last week the 1 uF ceramic caps came in, so I was able to finish it on Thursday (would have done it sooner in the week, but had too many other things going on.)  A minor issue that I found is that the 3.3V regulator  sits a little bit higher off the board than other regulators, so my heatsink doesn't make contact with the board.
The full parts list for the EasyPWR Deluxe:
1206 sized resistor (recommend a 2K+ value)
1206 sized LED
2.1 mm Barrel Jack
5x1 2.54 mm pin header
2x1 2.54 mm pin header
1 pin jumper
oki-78sr-5/1.5-w36-c 5v regulator (most expensive item other than the PCB itself)
1812L110/33MR 1812 size polyfuse
3.3V reg model MCP1825S-3302E/AB
2 1 uF 1206 caps for the linear regulator (C3 and C4 pads)
1 TO-220 heatsink
And of course the photos of the finished product below:
oshpark wrote 10/02/2017 at 04:03 point
well done!
mcu_nerd wrote 10/05/2017 at 00:37 point
Thanks!
