Part of a Bigger Mission: The ZERO Ecosystem
This stand isn't just a standalone gadget; it was designed alongside our Discord community as a companion piece for ZERO—a modular, fully repairable, open-source power bank utilizing swappable 18650 cells.
In a world full of glued-shut, planned-obsolescence tech, we are building a modular power ecosystem where the user is in control. The ZERO Stand is our first purely mechanical, open-source release to support that ecosystem.
- 🌐 Our Story (Website):
- https://go.nomorezero.com
- 💬 Hack with us on Discord:
- https://discord.gg/NEGxbPztXZ
- 📬 Kickstarter Campaign:
- https://www.kickstarter.com/projects/ctrlenergy/zero-portable-battery
Mechanical & Print Specifications
To ensure the print-in-place joints rotate smoothly without fusing, the model relies on precise physical tolerances:
- Hinge Clearance: Engineered with a radial clearance optimized for a standard
0.4 mmnozzle. - Recommended Layer Height:
0.2 mm(layer heights greater than this will cause the stepping layers of the hinge pin to fuse to the outer barrel). - Material: Works incredibly well in standard PLA, but prints beautifully in ABS/ASA for a premium, rugged matte finish that handles the heat of a hot car or travel bag.
- No Supports: The angles of the folding arms and the storage pocket are modeled with internal
45°chamfers, allowing the printer to bridge every overhang naturally.
CtrlEnergy
Atte Linna
Daniel Westhof
orcaslicer
