The pre-order campaign on Lectronz has reached its threshold, yeah! This means that placing a pre-order now means you will get a unit for sure. So if you would like to join the first production run, you can do that in the final day. Thank you!
Currently working my way though writing the lessons that will accompany the device. They will be a mix of computer history and funny assignments, suitable for a broad audience. Trying to get them peer reviewed as well…
